How Long is Your Clutch? (Lasting)
Old 08-15-2011, 11:30 AM
Alaska90's Avatar
so,
i've got a 90 ext cab, p/u, v6, 5 speed manual. i'm at 186K on the original clutch.
anyone beat that? (i'm wondering how many more K's i might expect.)
thanks.
-alaska
Old 08-15-2011, 11:49 AM
MaK92-4RnR's Avatar
are you the original owner?
im on my 2nd clutch at 158k. and my 3rd is on the horizon
Old 08-15-2011, 12:36 PM
snobdds's Avatar
I went 220,000 on the factory clutch. With me being such a quick learner, I promptly went out and bought an OEM clutch kit from the dealer. I expect to change it in another 210,000 or so...
Old 08-15-2011, 01:01 PM
Alaska90's Avatar
yes, i'm the original owner who stalled the thing the first day i drove it off the dealer's lot!
Old 08-15-2011, 01:06 PM
MKtaco_98's Avatar
ive got 140,000 on mine had to replace the clutch master and slave cylinder about 40,000 miles ago clutch was still in good shape
Old 08-15-2011, 01:10 PM
pruney81's Avatar
I had an 87 4Runner that I bought from the original owner and learned to drive stick on. I bought it at 192K miles and the clutch went at 215K. It probably could've gone longer than that if I didn't burn it up learning to drive on it.
Old 08-15-2011, 01:26 PM
TNRabbit's Avatar
218,000 on the original clutch. I'm at 260k now with a MarlinCrawler HD clutch. Still have the original master & slave cylinders.
snobdds's Avatar
And that is the key to a long lasting clutch...you have to know how to drive it without burning it up. If you drive it right, then they can go hundreds of thousands of miles...
Old 08-15-2011, 01:29 PM
MaK92-4RnR's Avatar
Whats the difference between an OEM and MC HD clutch? any reviews from people that have used it? i'm thinking of going with the 2,100 lb. is this gonna be any different than my OEM?
Old 08-15-2011, 02:50 PM
Tubbyfatty's Avatar
220k, 18k of it is what i put on, 3rd or 4th owner, 3rd clutch marlin crawler
Old 08-15-2011, 02:56 PM
Tubbyfatty's Avatar
Stronger clamping force. I got the 1200lb one and the pedal is just as soft as the stock clutch, but shes never slipped on me, only when I wanted it to.
Im sure the 2100lb one will a stiffer pedal
Old 08-15-2011, 03:02 PM
MaK92-4RnR's Avatar
isn't 1200 lb the same weight as a stock clutch? im pretty sure it is...
I wouldn't mind a stiffer pedal. grip and longevity would be nice
Old 08-15-2011, 03:09 PM
snobdds's Avatar
OEM is 900lbs IIRC.
2100lbs is way overkill for a DD truck, but I have no idea what you use your truck for. I am just asuming it is a little wheeling and for the most part a DD. However, your left leg is going to be huge, just like pop-eye's right arm.
Old 08-15-2011, 03:12 PM
MaK92-4RnR's Avatar
Originally Posted by snobdds
OEM is 900lbs IIRC.
haha yeah its a DD/Weekend warrior.
If i wanted a little bit more longevity, strength and grip, what would you guys go with?
Old 08-15-2011, 03:16 PM
SCToy's Avatar
I was thinking to go with te 1600 lb IIRC from marlin, I keep waiting for it to go, but haven't had any problems with it yet. Seems like the best upgrade without going overkill.
Old 08-15-2011, 03:18 PM
SCToy's Avatar
Oh 155k miles on the 81 and 193k on the 95, but when doing the head gasket I found some evidence the tranny was pulled before on the 95, so I assume it's not the original clutch, but that's just a guess. The 81 is definitely te original according to the original owner.
Old 08-15-2011, 05:08 PM
Mr_Random's Avatar
I wouldn't bet on mine being anything but original... regardless, it's only slipped on me after hours and hours in deep snow. I think the throw out bearing is going too. If it is original, it's right around 300k... clutch and MC are perfect. Compared to any American clutch though, it's beautiful!
Old 08-15-2011, 07:41 PM
Dirt Driver's Avatar
My father bought a '94 like mine new in '94 and the original clutch got changed when we pulled the original engine out at 280,000mi. To be fair, he put at least 70% highway miles on it, so the clutch didn't get used much. I got my truck used and don't know if the clutch was ever changed, but if it hadn't, it went 180,000mi with lots left. I still have the old one, so I could see if it's at least an OEM brand.
Old 08-15-2011, 07:44 PM
Swimmerboy2112's Avatar
First one was changed out not long before I bought the truck. It had done 240K miles and taught 2 girls (PO's daughters) how to drive stick!
Old 08-15-2011, 08:10 PM
Diablo22RE's Avatar
lol
got any pics of the truck?
Quick Reply: How Long is Your Clutch? (Lasting)
