Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
How to I get this !@#$ rotor off?!!
I'm trying to replace the rotor and cv joint, but I am stuck. What do I do next to get this black thing off? (see below)
| Sponsored Links |
#2 (permalink) |
Sponsoring Member
Look online under repair info at Autozone. Diagrams and textual instructions.
http://www.autozone.com/addVehicleId...00c1528004d8da ![]()
__________________
WabFab Off-Road, LLC www.myspace.com/wabfab FOR SALE: 1987 4Runner GRAY FOR SALE: 1987 4Runner RED 6th Annual South East 4Runner Jamboree, May 22-25, 2009 Last edited by waskillywabbit : 08-30-2008 at 06:48 AM. |
#3 (permalink) | |
there are conical shaped split washers around each of the 6 bolts. tap tap tap. maybe a torch. don't bugger the threads on the studs though.
__________________
Quote:
#4 (permalink) |
Hammer!
Penetrating oil on those cone washers around those studs. Hit the housing w/ a hammer at the side right where the cone washer is inserted and it will pop right out. Keep your eye on them as some realy do pop right off. Two are already out it looks like so repeat 3 more times. Try not to deform the metal too much. I see a little deformation on the one at the top so they've likely been off before. Good luck.
#5 (permalink) | |
Sponsoring Member
Quote:
Use a brass drift on the stud and tap the brass with a hammer and they'll pop right off up to the brass drift. ![]()
__________________
WabFab Off-Road, LLC www.myspace.com/wabfab FOR SALE: 1987 4Runner GRAY FOR SALE: 1987 4Runner RED 6th Annual South East 4Runner Jamboree, May 22-25, 2009 |
#6 (permalink) |
heat the cone washers up with a torch propane works for 20 seconds then tap the side of add flange with a hammer lightly and they will pop like hot pop corn
__________________
1991 HILUX SURF SSR-X 2-lte turbo diesel with upgraded head tons of cool options you dont get in north America RIGHT HAND DRIVE,auto,push button 4wd,turbo timer,31.1-.50.15 bfgs,factory fender flares,window flares. CAR DOLLY sirius TUNED TO HOWARD 100 trail ifs rig goldie fate unknown blue 93 srf 4runner NEW TRAIL RIG IN POGRESS ifs welded rear few mods for now rebuilding fj 60 series front axle for future s.a.s |
#7 (permalink) |
I used a brass drift on either the end of the studs of on the split of the conical washer. hit each one of them. some with pop off others will just loosen to the point where you can wiggle the rotor off easily
__________________
Iverson 89 reg cab pickup, 31x10.50 high tech retreading MTR's, 22RE stock,needs paint job ( IN PROGRESS) My DD 75 jeep CJ-5 only paid $.88 for it 04 jeep grand Cherokee, wifes DD 97 Chevrolet K1500 Z71 I own four 4x4's with $4.00 a gallon gas, what the heck am I thinking. Sometimes, War is the answer |
#8 (permalink) |
Sometimes you can tap a small straight blade screwdriver into the split in the cone washer and pull it out. I do that on class 8 trucks, same cone washer on the drivers.
#9 (permalink) |
There are 2 threaded holes on the black thing with nothing in them. Find 2 bolts that fit, I think I used 2 of my hood bolts since I had it off anyways. Tighten the 2 bolts in the holes, alternate between them and you will see the black thing start to move. You don't need to loosen it too far. About 1/8" gap will be enough. Then simply remove the bolts again. The cone washers will fly off so watch your eyes. You might have to tap a couple but nothing difficult at all. There is no need for a torch or anything like that. I didn't even have to use penetrating spray.
Good luck, Jason
__________________
1993 Toyota 4WD Ex-Cab Auto 31 10.5 15 BF Goodrich A/T's Front and rear diff. breathers Aisin manual hub swap Clarion Pro Audio CD player MB Quart speakers 3VZ-E V6 with fresh rebuild: Block bored 20 over Engnbldr master rebuild kit Heads rebuilt Engnbldr 1mm o/s valves Weasy2k stage 1 cams Cleaned and balanced injectors LCE ceramic street header kit LCE pro flow exhaust with cat delete http://picasaweb.google.com/Green93Toy/MyToy# |
#10 (permalink) |
Forgot to mention...keep the nuts threaded on just a couple of turns. They will prevent the cone washers from flying off and getting lost.
__________________
#11 (permalink) | |
Quote:
Thanks everyone for the replies so far. Chris Charlotte, NC |
#12 (permalink) |
no heat them up and tap with hammer im telling you takes 5 minutes! for both sides
__________________
#13 (permalink) |
x10 on the brass drift and a hammer. Don't beat on the housing. I used a piece of aluminum bar stock on mine. That also works.
#14 (permalink) | |
Quote:
Or if you need an excuse to play with your torch then do that. But why would Toyota put those handy little threaded holes there if they didn't intend for you to use them??? Jason
__________________
#15 (permalink) |
I have a question to go with that.. after you get it off how do you seperate the rotor from the hub housing and whatever else that is that holds the bearing and seal on the back side of the rotor???
#16 (permalink) |
The rotor is bolted to the back side of the hub.
__________________
Dale "America is in a hole and it's getting deeper every day. We import 70% of our oil at a cost of $700 billion a year - four times the annual cost of the Iraq war." T. Boone Pickens Check out the plan: http://www.pickensplan.com/index.php and http://www.cngnow.com/EN-US/Pages/default.aspx |
#17 (permalink) |
Make sure you have a 54mm socket for the wheel bearing nuts... Don't use a stake.. IT DOESNT WORK...
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#18 (permalink) | |
Quote:
Also a lot better than beating the housing with a hammer.
__________________
IFS SAS My mods aren't bling enough for the signature line. -All Terrains are for when you know how to drive. |
#19 (permalink) |
Great success in getting that part off. You can see it on the left there, removed. Two questions now:
a) I noticed a rubber seal on that part I removed. What is it called, and where can I get a replacement seal? b) The next step, I believe, is to removed that large nut in the center. I think it is 54mm, can anyone confirm that? ![]() |
#20 (permalink) |
as for the seal, i do not know. yes the nut is a 54mm or 2 1/8 standard socket. i just bought one for mine at sears $28 and they are 3/4 in drive so make sure you have a 3/4" rachet or a step down from 3/4 to 1/2. i believe on yours there will be 2 54mm nuts with a washer in b/w that has tabs to fold down over the front and rear nut.
good luck |
