How hard is it to drop 2gen Gas Tank??
OK! I did some searching and didn't get much. I'm asking because I'm going to make some sliders for my Daughters 95 4runner and I want to bolt them on. The gas tank is close to the frame and I want to put a plate and nuts on the inside of the frame. Maybe I can just drop it down a little and push it aside to get in and bolt up the sliders? So whats involved?
Ok well on my 95 when I droped my gas tank it was not easy. I did it when I put new tortion bars in. Un bolting it is very easy. Except when you have to get the gas line fitting of. I rounded off my fitting because itwas seized. I just snipped the gas line off and put a hose in and some clamps. There is a access area you can get to under the passenger rear seat and then under the carpet. That will give you access to the top of the tank to get the gs line fittings off. Hope this helps.
skoti89
09-11-2015 07:46 AM
pyramid
07-30-2015 10:05 AM
TURBOrunnerNM
07-22-2015 11:01 AM
