How to find out what gear are in my truck?
Old 11-01-2013, 01:50 AM
Hooperdog's Avatar
Arrow How to find out what gear are in my truck?
How can I tell what gears I have in my truck? It's a 94 22re 5 speed 4wd regular cab. Is there a sticker or code on the door that will have this info.
Thanks
Old 11-01-2013, 02:15 AM
jb451's Avatar
There's a link to a FAQ section that will tell you, right above this thread my friend
Old 11-01-2013, 07:10 AM
phildelfino's Avatar
http://www.off-road.com/trucks-4x4/t...ion-18588.html
there is a metal tag under my hood near brake master cylinder riveted to the firewall with technical info. get axle code and click link above.
Old 11-01-2013, 08:17 AM
Hooperdog's Avatar
Great info, thanks my tag was on my door jam. looks like 410's
Old 11-19-2013, 12:57 PM
Dongskie's Avatar
Good day guys!
I happen to find the axle codes "A03A" on my Utility wagon, and I was wondering from which other Toyota vehicles can I get a lower ratio diff with a bolt-on diff of the same size and lower ratio..
I was told that this is a 43/10 ring and pinion..
THank you all!
Old 11-19-2013, 01:14 PM
thefishguy77's Avatar
It depends if you have a 8" or 7.5" rear end. If its 2wd I believe you are 7.5" and 4wd ifs is 8" in the rear and 7.5" up front. Not sure if this helps or not.
Old 11-20-2013, 09:13 AM
Dongskie's Avatar
Yes I have a 2WD, 7.5" then
Thanks
Old 11-20-2013, 09:18 AM
I don't know if all 2wd are the same might be a bigger rear end in "1ton"'s. just a thought
Old 11-20-2013, 10:03 AM
Dongskie's Avatar
Here is my vehicle.. 2C diesel engine + G52 Tranny + A03A Diff. 14inch wheels and tires.
Old 11-20-2013, 03:31 PM
Stevesk88's Avatar
Dude that thing is pretty cool
Old 11-20-2013, 03:44 PM
rattlewagon's Avatar
1st gen runners and 2nd gen pickups its under the hood. 2nd gen 4unners and 3rd gen pickups its in the drivers door jam.
An a03a is a 7.5" with 4.10 and 2 pinion open dif. Thats a cool wagon! We dont get those in the states. The link above can decode you gear code, not sure whats compatible, like I said.. we dont have those here.
Old 11-21-2013, 12:23 PM
Dongskie's Avatar
Thanks mate!
My wagon is very slow LOL..
Old 11-22-2013, 01:24 AM
Dongskie's Avatar
Thanks Steve!
vasinvictor
01-20-2016 12:39 PM
ACZR
06-23-2015 07:55 PM
streetuner15
06-18-2015 10:59 PM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: How to find out what gear are in my truck?
