How Do I...? Help ASAP. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-09-2008, 02:44 PM   #1 (permalink)
Belize Off Road Team's Avatar
Send a message via MSN to Belize Off Road Team
Post How Do I...? Help ASAP.
i just picked up a 3rd brake light from the roof of a 90+ pick-up and i want to install it on my 91 4Runner. i was told that the 90/91 came with the wires for the 3rd brake lights but were never offerd as an option. same thing with the upper rear speakers by the cargo lamps, wires are there but never an option till 92+.?
So does anybody know what the scoop is with wires? i know that i am going to have to move the wiper motor over a little bit and drill one hole for the wires and 3 more holes for the screws. is there anything i should be be worried about? the sooner i get answers the sooner i get it installed and get pics up, so please any info will help.
__________________
-Phyl
1991 Hilux Surf SSR-G Petrol 3.0L V6 200,000kms l Rancho RS5000 l 31"x10.50"xR15 Pro Comp Xterrain l K&N Air Filter
l PP 1" Lift Coil Springs l Optima Blue Top l 12" JBL Subs l Alpine Type R l 80/100W Hella H4 l 1st Gen Roll Bar Mod l FT/RR Diff. Breathers l Smittybilt XRC8 Winch l ARB Bull Bar l
トヨタ|NEVER QUIT
Belize Off Road Team is offline
Old 04-09-2008, 04:05 PM   #2 (permalink)
can anybody help me please
__________________
-Phyl
トヨタ|NEVER QUIT
Old 04-09-2008, 04:10 PM   #3 (permalink)
just a 22re's Avatar
Send a message via AIM to just a 22re Send a message via Yahoo to just a 22re
yeah man i wish i knew but i dont any idea if the 87 came with that there rear speaker thingy too?
__________________
GO TEAM LAZY!!
my name is ALLAN
yeah its a 22re 5-speed 4wd 1987 4runner with a cam, snorkel, welded rear
Quote:
Originally Posted by SwampThing View Post
Going wheeling and going swampthinging are two totally different things. Wheeling is doing something with the expectation of having fun in the process. Swampthinging is doing something and knowing you'll probably end up in a hospital in the process.
http://www.yotatech.com/misc.php?do=flashchat
www.myspace.com/whatsadisplayname
just a 22re is offline
Old 04-09-2008, 04:14 PM   #4 (permalink)
not to my knowledge because the top is removable. i'm going to check tomorrow for the wires if i cant get any help on here.
__________________
-Phyl
トヨタ|NEVER QUIT
Old 04-09-2008, 04:20 PM   #5 (permalink)
yeah i dont know anything about them but if you take the cover for the rear motor off the plug should be there aye? if not try at the main harness on the drivers side by the lower plastic panel im just shooting blanks here so i hope it helps man
__________________
GO TEAM LAZY!!
my name is ALLAN
Old 04-09-2008, 04:22 PM   #6 (permalink)
it should help, thank you.
__________________
-Phyl
トヨタ|NEVER QUIT
Old 04-09-2008, 06:32 PM   #7 (permalink)
Noltz's Avatar
I was going to do the same thing, using a LED 3'rd from a GM Safari (lower profile). My intention was just to grab the 12v+ wire at the drivers side brake bulb and pigtail it off there. LEDs draw very little power. I think you'll be fine with the same setup.
__________________
•-Noltz-•
'95 4Runner SR5, mostly Stock, w/OBA & AirLifts. His.
'97 4Runner Limited, Stock w/E-Locker & 285s. Hers.
'91 4Runner, 3" BL, 35's & 8000# Winch.
SOLD
Noltz is offline
Old 04-09-2008, 06:39 PM   #8 (permalink)
bigt's Avatar
yup.. i have a 3rd brake light on my 94 trail rig with no options and no brake light on my 93 with ac and all options... i can look and see if the wires are there tommorow
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan,
130,000 km 31 bfg a/t auto
current build
1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/
bigt is offline
Old 04-10-2008, 06:42 AM   #9 (permalink)
Quote:
well i had a look at the bulb from the 3rd brake light and it is different to any other bulb. it is bigger than the 194 used in the clearance lights but smaller than the 1156 used in reverse/indicators.
and i ripped the panel out today and there are no wires going up to where the brake light goes. but they gave me 5' of the wires with the brake light so i'm going to have to run it down and tie into the brake lights but i got two wires with the brake light and i am confused. what are the wires for?
green with white stripe and white with black stripe.
__________________
-Phyl
トヨタ|NEVER QUIT
Old 04-10-2008, 07:00 AM   #10 (permalink)
Blizzard's Avatar
Send a message via MSN to Blizzard
My '94 4Runner has an orange plug below the wiper motor trim for the 3rd brake light.
I've never seen an European 2nd Gen 4Runner with stock 3rd brake light but the plug is here, I put an aftermarket one (Inside the trunk, bolted to the plastic piece) and it works OK.
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler Auto – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35's, FR&RR E-Lockers and too many things more to write...
Blizzard is offline
Old 04-10-2008, 07:54 AM   #11 (permalink)
uh well as far as i know on the pickups anyway it wasnt offered until 94 because it wasnt required until 94. I dont know about the 4runners but I dont think theres gunna be wires there.
MMA_Alex is offline
Old 04-10-2008, 11:47 AM   #12 (permalink)
i check and didnt see any, so i pulled out the taillights, followed the 2 wires from the brake light into the cargo area(pulled the side panel) and cut off a small section of coating, wrapped the 3rd brake light wires to the brake wires and it works! with an LED, so now i just have to punch 3 holes for the mounts and 1 big hole for the wires/gromet and mount it. i'll try and mount it tonight.
__________________
-Phyl
トヨタ|NEVER QUIT
Old 04-10-2008, 01:34 PM   #13 (permalink)
stormin94's Avatar
I think I have a thread of an XM satellite radio install. I routed my antenna through the 3rd brake light, and I have a pic from the inside with the wiper motor. I'll look.
__________________
1994 Toyota 4Runner SR5 4X4
213,000 miles and counting
3.0 V6, 5 speed
10/15 MPG city/hwy(with 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighter 100 Watt lights
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is offline
Old 04-10-2008, 02:15 PM   #14 (permalink)
stormin94's Avatar
Here's my thread. It's not quite what you are doing, but I did remove the 3rd brake light, and there are some decent pics of that area, and it shows how it is mounted.
http://www.yotatech.com/f123/beyond-...arning-139807/
__________________
3.0 V6, 5 speed
Current Mods
Brushguard
Future Mods
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Help Asap hmmwv15 Off Topic Talk 8 05-25-2007 05:31 PM
Help Asap!!! mburg28 86-95 Trucks & 4Runners 6 09-22-2006 08:34 AM
Need Help Asap 89runner 95.5-2004 Tacomas & 96-2002 4Runners 4 03-19-2005 12:53 PM
need help ASAP!! redtoy92 95.5-2004 Tacomas & 96-2002 4Runners 11 08-01-2004 01:11 PM
I Need Help ASAP!!!! Stump1883 95.5-2004 Tacomas & 96-2002 4Runners 4 12-11-2002 12:17 PM
2009 InternetBrands, Inc.
