How do I get my speedometer working?
I replaced my transmission (with mechanical speedo) with a newer one (electric sender).
So now I just have the mechanical speedo cable hanging there. I know marlin makes one to convert it from a mechanical to electric sender, but what if I need it the other way around??
Your beat I think. I am not sure if you can take the guts out of the mechanical one and put it in where the electric one is. I think the electric is in all chain driven cases and the mechanical is in the gear driven cases so ou may be out of luck. Change the dash.
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
yes, you will have to change the instrument cluster as far as I know. Grab the wires from a junkyard and a cluster, I think you'll be far happier with the electric speedo anyways. When I do my tranny swap, I am going to a electric speedo to prevent my cable from chirping sometimes despite being lubed. also, the needle will be much steadier. Mine jiggles and wiggles, haha.
ashersullivan88yota
01-18-2022 05:37 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
madxman21
07-09-2015 10:26 AM
