How do I get codes
Old 06-29-2010, 09:57 PM
4x4jeffyota's Avatar
How do I get codes
I tried to search it but can't find the answer. How do I get code for my 86 Pickup?
Old 06-29-2010, 09:59 PM
flecker's Avatar
Location: White Mountains, Arizona (Yes it does snow in AZ)
Paper clip and TE1 and E1 in the diagnostic box. It should be right beside your fuse box under the hood unless it is an early 86. Then there will be a plug on the drivers side by your coil.
Don't you have a haynes book or something? Time to drop 20 buxx and get one sir.
Old 06-29-2010, 10:16 PM
i didnt think about a Haynes book. thanks man
Old 06-30-2010, 12:02 AM
k808soljah's Avatar
here's what the codes mean, if you don't have these yet...
11
LOSS OF POWER SUPPLY TO ECU
--IGNITION SWITCH/CIRCUIT
--MAIN RELAY/CIRCUIT
--ECU
RPM SIGNAL-NO SIGNAL TO ECU FROM DISTRIBUTOR ("Ne" OR "G") AFTER ENGINE HAS BEEN CRANKED
--DISTRIBUTOR/CIRCUIT
--STARTERSIGNAL CIRCUIT
--IGNITER/IGNITER CIRCUIT
--ECU
13
SAME AS ABOVE BUT AFTER ENGINE HAS RUN AT 1,000-1,500 RPM
--DISTRIBUTOR/DISTRIBUTOR CIRCUIT
--ECU
IGNITION SIGNAL--NO "IGF"SIGNAL TO ECU
--IGNITER AND IGNITION COIL/CIRCUIT
--ECU
OXYGEN SENSOR SIGNAL/OXYGEN SENSOR HEATER SIGNAL
OPEN OR SHORT IN OXYGEN SENSOR OR OXYGEN SENSOR SIGNAL
WATER TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN WATER TEMP. SENSOR SIGNAL
--WATER TEMPERATURE SENSOR CIRCUIT
--ECU
INTAKE AIR TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
--INTAKE AIR TEMPERATURE CIRCUIT
--INTAKE AIR TEMPERATURE SENSOR
--ECU
25
AIR/FUEL RATIO LEAN INDICATOR--LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
--INJECTOR FAULT(S)
--FUEL PRESSURE
--OXYGEN SENSOR
--AIRFLOW METER OR MAP SENSOR
--IGNITION
--ECU
26
AIR/FUEL RATIO RICH INDICATOR
--SAME AS ABOVE
--COLD START INJECTOR
27
SUB-OXYGEN SENSOR CIRCUIT OR SUB-OXYGEN SENSOR HEATER CIRCUIT
--SUB OXYGEN SENSOR/HEATER/CIRCUIT
--ECU
28
No.2 OXYGEN SENSOR/OXYGEN SENSOR HEATER
--SAME AS CODE 21
MANIFOLD AND/OR AIRFLOW METER SENSOR SIGNAL CIRCUIT
--AIRFLOW METER/CIRCUIT
--MANIFOLD PRESSURE SENSOR/CIRCUIT
--ECU
32
AIRFLOW METER SIGNAL (VANE-TYPE)
--AIRFLOW METER./CIRCUIT
--ECU
14
34
TURBOCHARGER PRESSURE--ABNORMAL TURBOCHARGER PRESSURE
--TURBO CHARGER
--AIRFLOW METER/MANIFOLD/TURBOCHARGER PRESSURE SENSOR
--INTERCOOLER SYSTEM
--ECU
35
TURBOCHARGER PRESSURE SENSOR SIGNAL
--TURBOCHARGER PRESSURE SENSOR
--ECU
7
41
THROTTLE POSITION SENSOR SIGNAL--OPEN OR SHORT IN TPS SIGNAL
--TPS SENSOR
--TPS SIGNAL/CIRCUIT
--ECU
9
42
VEHICLE SPEED SENSOR SIGNAL CIRCUIT--NO SPD. SIGNAL FOR SEVERLA SECONDS
WHILE VEHICLE IS OPERATED UNDER HEAVY LOAD (TPS/MAP/AIR FLOW INPUTS)
--SPEED SENSOR/CIRCUIT
--ECU
10
43
STARTER SIGNAL--NO "STA" SIGNAL TO ECU UNTIL ENGINE SPEED EXCEEDS 800RPM
--ECU
11
51
SWITCH SIGNALS
IDL (tps) CONTACTS OFF, NEUTRAL START SWITCH OFF, A/C SWITCH "ON" SIGNAL TO ECU
WITH DIAGNOSTIC CHECK CONNECTOR SHORTED
--A/C SWITCH/CIRCUIT
--A/C AMPLIFIER
--TPS/CIRCUIT
--NEUTRAL START SWITCH/CIRCUIT
--ECU
12
52
KNOCK SENSOR SIGNAL--OPEN OR SHORT IN KNOCK SENSOR SIGNAL
--KNOCK SENSOR/CIRCUIT
ECU
13
53
KNOCK CONTROL SIGNAL IN ECU
--ECU
71
EGR VALVE MALFUNCTION--EXHAUST GAS TEMPEATURE BELOW SPEC. FOR EGR CONTROL
--EGR SYSTEM
--EGR GAS TEMPERATURE SENSOR/CIRCUIT
72
AIR CONDITIONER COMPRESSOR RELAY/RELAY SIGNAL
--A/C COMPRESSOR RELAY/CIRCUIT
--ECU
moparbay
10-06-2015 09:24 AM
bradahman
10-01-2015 09:24 AM
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
Draven023
09-26-2015 12:41 PM
Quick Reply: How do I get codes
