How do I check ignitor on 91 toy v6 4x4?
Just joined yotatech today...because I need help. My 91 toy v6 4x4 is cranking but not starting. There is no spark from the coil - ohms reading of coil is within spec. Next step I want to do is to check the ignitor. The ENGINE CHK light does not come on when ignition switch is in ON position.
Thank you for your immediate help...
There is no multi-meter check for the ignitor. http://www.ncttora.com/fsm/1990-1995...e/onvehicl.pdf Personally, I've never heard of a parts store checking them, but if you can find one that would definitely be the way to go. (Once you've completed all the checks in the Manual.)
Ive never tested a toyota igniter. But ive tested chevys and hondas at parts store. Try taking it to a napa, oreileys, or something along those lines. They will probably take it to the back of the room and hook wires up to it.
some drunk guy
08-03-2021 06:09 PM
primordialbeast117
12-19-2015 12:23 PM
bryan34w
12
09-30-2015 02:50 PM
