HOw TO discharge Air Conditioning - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 08-17-2008, 03:25 PM   #1
How To discharge Air Conditioning?
HI All,
First time pulling an engine and I am elbows deep in the disassembly, but I've hit a snag. Working on a 1995 4Runner with the 3vze I need to disconnect the lines between the ac compressor and the condenser. How do I go about discharging the A/C system before undoing the lines?
Thanks
Ross
freshspecbluegt is offline   Reply With Quote
Old 08-17-2008, 03:59 PM   #2
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
I believe you need a recovery machine for the refrigerant......
a4runnerfreak is offline   Reply With Quote
Old 08-17-2008, 04:17 PM   #3
just a 22re's Avatar
take a really big wire cutter and cut the line just dont go breathing around the stuff that comes out cause it will freze your lungs really fast and kill ya!!!
but really though dont do that you might get a lot of picketers around your house or something lol
if you wanna do it and do it my the law then yes what freak said if you dont care then cut it give it a small but good hole and run let it sit and let it be
but however it is illegal do do this!!
just a 22re is offline   Reply With Quote
Old 08-17-2008, 04:27 PM   #4
abecedarian's Avatar
you have two options- recover the refrigerant, which takes special equipment to do, or discharge into the atmosphere. option #2 is illegal.
if you do release into the air, as mentioned avoid breathing the gas and oil that will be released. it can quite quickly asphyxiate you, and is also toxic
abecedarian is offline   Reply With Quote
Old 08-17-2008, 07:47 PM   #5
Matt16's Avatar
Matt16 is offline   Reply With Quote
Old 08-18-2008, 12:04 PM   #6
Thanks for the info
Old 08-18-2008, 12:34 PM   #7
misto's Avatar
just simply push the valve on the high or low side in with a small screw driver like letting air out of a tire
misto is offline   Reply With Quote
Old 08-18-2008, 01:01 PM   #8
Tofer's Avatar
Quote:
thats how i did mine when i took my 3.0 out
Tofer is offline   Reply With Quote
FS[PacNorWest]: 1992 4runner - 5VZ swap - Lifted Swim Vehicles - Trailers (Complete) 9 01-04-2016 11:47 AM
04 Taco Engine Ping/Spark knock w/ only 79,000 Tacoma1313 95.5-2004 Tacomas & 96-2002 4Runners 2 08-17-2015 06:44 PM
First Truck, DD/Adventure Mobile 94ofCanada 86-95 Trucks & 4Runners (Build-Up Section) 3 08-14-2015 07:37 AM
95 pickup running rich, low power Sidherish 86-95 Trucks & 4Runners 1 08-02-2015 02:42 PM
FS[SouthEast]: 99+ center console, rear air deflector, lift spacers, steering wheel terminator Misc Stuff (Vehicle Related) 3 07-27-2015 08:13 PM
Tags
4runner, ac, air, condition, conditioning, discharge, discharging, freon, how, illegal, powered, refrigerant, system, toyota, vbulletin, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
