How can I test if my Fuel Sending Unit and Pump are bad / good?
Old 07-13-2010, 07:43 AM
89whitetoyota's Avatar
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
I think I need to replace/check my fuel pump and sending unit. In the morning no matter what type of day, I have to crank the motor for 20-30 seconds before the motor will stay running.
It takes about 5-10 minutes for the idle to smooth out and get up to proper idle rpms. It starts and runs at like 100 rpm then slowly, I mean SLOWLY, get up to 500rpm then a little faster getting to 800-900.
However, if I drive the truck again say and hour later, it will fire right up and be about right.
Also I can get the truck moving, on flat ground up to 80 miles an hour but as soon as I need to go up an incline the speed and rpms drop radically, also when I am at a dead stop, sometimes taking off the truck is a slug, wont get out of its own way.
How can I check proper PSI for fuel to see if my stuff in the tank is toasted, also what is the proper PSI supposed to be for a 22re?
Truck also has 202k on the odometer.
Old 07-13-2010, 07:46 AM
waskillywabbit's Avatar
www.ncttora.com/fsm
Read. Learn. Live long and prosper.
Old 07-13-2010, 07:51 AM
I have a 92 pick up, there isn't one for that, do I just use the 93 pickup manual?
Old 07-13-2010, 08:02 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Yeppers.
JF9243176
10-08-2017 04:21 AM
OffroadRalph
07-02-2015 07:28 PM
Jake 85 sr5
07-01-2015 06:49 PM
JF9243176
06-24-2015 04:53 AM
XtremeOff-Road
16
06-27-2002 07:32 PM
Quick Reply: How can I test if my Fuel Sending Unit and Pump are bad / good?
