Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
How can I tell if the EGR valve is stuck open?
__________________
'95 4WD 22R-E 4Runner, 5spd, 242k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD Last edited by YotaJunky; 10-23-2005 at 06:15 PM. |
#2 (permalink) |
Personal
Sales Rating: (2)
One tip is to tap on the EGR valve body with a screwdriver or small hammer to see if the idle smooths up. If the valve is sticking open, the tapping will free it up so that is can close. If the valve is stuck open too bad, this won't work. The other way to check it is to remove it, and with the valve upside down, fill it with carb cleaner or similar and see if fluid leaks out (it should not). Then you can pull a vacuum on the valve and it should open and release the solvent. A pistol cleaning kit and solvent work well to clean out the insides of the valve.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad - YotaTech discount code Gettin'Off 4WD Club |
#3 (permalink) |
Personal
Sales Rating: (0)
If I remember correctly, you can check the EGR valve by sucking on the vacuume line going into the EGR valve. Your truck should idle rought or cut off if it is working properly. You can also try hooking a vacuume line from your plenum to your EGR and it should idle rough. I used the small hose that goes around to the brake booster.
I think that is the right way to do it from what I can remeber. I'll check it tomorrow afternoon jut to make sure. Well, hope you get it figured out! Have fun. ![]() Daniel |
#4 (permalink) | |
Personal
Sales Rating: (2)
Quote:
__________________
#5 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
That makes good sense. I'll give it a try. Can I use a separate line connected to the air chamber as a vacuum source? I noticed a couple of plugged up lines along the passenger's side of the plenum that I may be able to unplug and then connect with an extra hose. If not, I'll have to get myself a vacuum pump. Troy
__________________
'95 4WD 22R-E 4Runner, 5spd, 242k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD |
#6 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
I hope I figure it out also... Thanks for the encouragement. Troy
__________________
'95 4WD 22R-E 4Runner, 5spd, 242k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD Last edited by YotaJunky; 10-23-2005 at 08:05 PM. |
#7 (permalink) |
Personal
Sales Rating: (2)
A small hand operated vacuum pump with a gauge on it is very handy. You can use the pump for testing vacuum operated things and the gauge can check vacuum readings and you can even fit one out for bleeding brakes and clutches:
![]() http://www.harborfreight.com/cpi/cta...emnumber=92474
__________________
#8 (permalink) | |
Personal
Sales Rating: (0)
Quote:
Not sure I understand why that would not work. ![]() Maybe you guys were both saying the same thing in different words.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#9 (permalink) |
Personal
Sales Rating: (2)
I suppose that would work, of course assuming the EGR was the cause of the problem. It could also change the idle, for example if the EGR was not able to close fully due to clogging but it could still open farther. And in that case tapping on it may not be enough to close it. Bottom line is there is probably no 100% test with the valve in palce to see if it is working properly or not.
__________________
#10 (permalink) |
Personal
Sales Rating: (0)
[OP]
I ran the EGR system through a battery of FSM tests and I'm confident that it's functioning as it should. That rules out the EGR valve, VSV for the EGR, the EGR modulator and vacuum hoses connected to the aforementioned. The rough idle continues to persist and I'll look elsewhere now.
Troy
__________________
#11 (permalink) |
Personal
Sales Rating: (2)
I've run the FSM tests as well and noted that they mostly check that the valve is opening properly. So you might still have a problem with the valve closing properly. Have you tried the tapping test? That was a trick shown to me by a Toyota dealer mechanic and it does seem to be a good diagnostic tool.
__________________
#12 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
Troy
__________________
#13 (permalink) |
Personal
Sales Rating: (2)
Either replace or test/clean it off the engine would be some options.
__________________
#14 (permalink) |
Personal
Sales Rating: (0)
read both rough idle posts.
My 3vze idles with the screw in all the way at 250 RPM. I noticed no mention of spark plugs. I had a camry that was so reliable, i forgot to change them for a VERY long time. idle got bad. Changed out REALLY worn plugs and it ran like new again. check out those plug wires while you have 'em off. since you did all the FSM tests, I think you have the simple ohm meter to do it! Also, cleaning intake and throttle body makes a 150 RPM difference in my truck. It seems like the goo on the back of the throttle butterfly and the venturi there has a lot to do with it. I spray in intake cleaner with the car running and my hand on the throttle to keep it running. bog it down with intake cleaner, let 'er clear out, repeat. note idle speed is higher again. adjust as required. |
#15 (permalink) | |
Personal
Sales Rating: (0)
Quote:
"The other way to check it is to remove it, and with the valve upside down, fill it with carb cleaner (or similar like isoproply alcohol, etc) and see if fluid leaks out (it should not). Then you can pull a vacuum on the valve and it should open and release the solvent. A pistol cleaning kit and solvent (or just intake cleaner and a toothbrush) work well to clean out the insides of the valve."
__________________
#16 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
I appreciate your input, and please keep them coming. These threads help all of us. Troy
__________________
'95 4WD 22R-E 4Runner, 5spd, 242k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD Last edited by YotaJunky; 10-26-2005 at 11:28 AM. |
#17 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
I'll do that this weekend. Thanks for the input. I'm leaning more towards a fuel supply or clogged injector(s) problem. I Just did a cylinder balance test by pulling out one plug at a time and checking for a drop in rpm. There didn't appear to be an issue there. I'm now looking at the temperature sensor beside the CSI timer switch. Thanks again for all your input! Please keep them coming... Troy
__________________
'95 4WD 22R-E 4Runner, 5spd, 242k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD Last edited by YotaJunky; 10-26-2005 at 11:30 AM. |
| Tags |
| 12, 1uz, 86, bad, bogs, check, checking, egr, hot, open, sicking, sticking, stuck, throttle, toyota, valve |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Egr Valve | bryonb | 84-85 Trucks & 4Runners | 2 | 04-05-2007 01:06 PM |
| 2 probs: throttle stuck wide open. whats that button above the gas pedal for? | AsahiMan | 86-95 Trucks & 4Runners | 4 | 03-26-2007 04:45 AM |
| stuck egr valve on 93 Camry | DuB | General Vehicle Related Topics (Non Year Related) | 1 | 03-25-2007 08:47 PM |
| EGR valve | desert whomper | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 12-02-2004 03:26 AM |
| EGR Valve | metal22lica | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 12-08-2002 08:44 AM |
