How can i remove the transfer case breather
Old 03-25-2010, 04:53 PM
lordhowe's Avatar
I'm attaching hose to the transfer breathers so i can keep mud/water out of them. while the Front and Rear breather is easily removed by a 14mm. the transfer case breather doesn't seem to be the same. it's round all the way to the bottom and i can't see how i can get a wrench on it.
can anyone shine some light on this?
many thanks
Old 03-25-2010, 05:02 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
AT? MT? V6? V6 AT?
transfer case breather???
Old 03-26-2010, 06:48 AM
lordhowe's Avatar
^^^ V6 5 speed and yes, Transfer case breather want a picture?
Old 03-26-2010, 06:49 AM
lordhowe's Avatar
here's a pic: https://www.yotatech.com/forums/f2/t...eather-191871/
Old 03-26-2010, 07:52 AM
awesome stuff... sucks if won't come out easier...
My advise is, go through the top. I'd take the shifter boots out and see if you can get a better look at it through the top.
If I had a case I could look at it for you...
Old 03-26-2010, 07:55 AM
is the shinny thing in the pic loose? like the diff breather cap thingies?
It looks like you remove the next piece down, the piece between the two visible bolts to pull the shifter out with.
4x4-runner
04-18-2017 09:08 PM
Chumlee780
11-13-2015 03:18 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
yourrealdad
07-29-2015 11:08 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: How can i remove the transfer case breather
