How can I do an "in driveway" 4wd check?
Old 05-06-2009, 10:28 AM
89whitetoyota's Avatar
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
What would be a good “in the driveway” or “in the garage way to test out if my 4wd is engaged? On my new red truck one of the hubs is impossible to turn, so I took one off the totaled white truck and cleaned it up and put some white lithium in it, now its turns like butter, but I want to make sure when I put the assembly on the truck it works right.
Old 05-06-2009, 10:34 AM
904_runner's Avatar
lock in the hubs and see if you can turn the drive shaft while in 4wd.
Or you can jack up the front end. lock the hubs and spin the drive shaft, the tires should move if its working.
Old 05-06-2009, 10:47 AM
Chutchman's Avatar
Do it one step at a time.
Start with everything unlocked (2wd) Truck on the ground
Lock your Tcase in 4hi
The forward driveshaft should be locked solid
Unlock (2hi)
The shaft should turn freely
Lock the left hub
Left half-shaft (between the diff and left wheel) should be locked solid
Unlock hub
Half-shaft should move freely
Lock the right hub
Right half-shaft should be locked solid
Unlock hub
If you do this you will know that all of the components function properly individually. If you lock it in 4-hi or lo with hubs in none of the shafts should turn freely.
Once you have the truck driving you can do a test. Put the truck in 4wd on dry pavement and crank the wheel all of the way to one side. Start pulling gently forward and the truck should bind up and stop rolling. Dont push it any farther than it will roll!! That can damage the drive-train. If it does not bind up you know something is not locking correctly. Pop the truck in reverse to un-wind the binding. Pop it back into 2hi.
ok cool thanls alot.
Old 05-06-2009, 10:49 AM
Unlock (2hi)
Lock the left hub
Unlock hub
Lock the right hub
Unlock hub
great break down, I will try this tonight.
Old 05-06-2009, 11:31 AM
ozziesironmanoffroad's Avatar
id just put it up on jack stands, (all 4 wheels off the ground) and start it, put it in 4x4, lock the hubs, put it in first, then let off the clutch. (or drive, if its an auto). a tire on the front and a tire on the back should spin. if not, then u got a problem. at least, thats the way i understand it.. someone correct me if im wrong.
adammtb
07-27-2015 11:57 AM
ripp96
07-25-2015 02:32 PM
jgwerth
07-16-2015 03:23 PM
TokyoD23
07-12-2015 06:01 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: How can I do an "in driveway" 4wd check?
