hot engine
Old 10-05-2009, 02:53 PM
Spanky's Avatar
hot engine
this started happening recently:
as im driving, my engine's heat gauge will slowly increase, and dip down almost into the red, just for a few seconds, and then go back to halfway and stay.
it will do it on the highway or stop and go traffic.
it wont do it again until a cold start.
any ideas?
Old 10-05-2009, 03:25 PM
toyota4x4907's Avatar
You need a new thermostat.
Old 10-05-2009, 03:31 PM
troubled87's Avatar
I just had this exact same problem with mine, turns out my head gasket had a TINY leak which lead to a bubble in the coolant system. the thermostat due to its location will not open till the block gets hot enough to open it.
make sure the coolant system is FULL, cycle and check again. An air bubble anywhere in the coolant system will cause that problem because it will find its way up to the thermostat after you shut the engine off and it quits circulating, cost me a head when i didn't worry about it thinking it as long as needle came back, no problem. I was wrong
Old 10-05-2009, 03:32 PM
Yes, Or you need to burp your cooling system. Might as well replace the t-stat.
Old 10-05-2009, 03:52 PM
Spanky's Avatar
ok, thanks. i will replace the thermostat first, and see what happens.
Old 10-05-2009, 04:13 PM
Spanky's Avatar
oh, one more question... what thermostat does everyone recommend ? and what temp ?
Old 10-05-2009, 04:19 PM
fireman1559's Avatar
what i would do is flush the the cooling system and replace the t-stat
Old 10-05-2009, 04:21 PM
I suggest an OEM dual stage t-stat from the Dealer. or a single stage OEM one. Aftermarket ones will work, but OEM are 97% the times better for our Yotas
190-195 temp is a good range.
bigjstang
08-25-2021 12:41 AM
the1998sr5
15
07-14-2020 08:35 PM
Poncho0206
07-10-2015 06:21 PM
Avenged
07-09-2015 07:55 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: hot engine
