high RPM hesitation
Old 09-21-2010, 03:51 PM
helidriver's Avatar
high RPM hesitation
Background: my fan/alternator belt broke the other day on the way to work in the morning. noticed right away. drove it around a bit on just battery power for a few miles. cool day most at night, got pretty warm but stayed just out of the red for about 5mins.
Just put new belt on and re-tightened all of them. no skweeks.
Present: Just drove for the first time over 50mph. first time in 5th gear.
right about 2100rpms on ACCELERATION only it starts "bumping, coughing?, hesitating?, missing?, ......? the harder I accelerate the worse it gets.....?
slow easy acceleration it's okay. down shifting spiking the rpms does just fine.
seams just an acceleration thing? WHATS GOING ON? i'm guessing timing issue?
Old 09-21-2010, 03:55 PM
HighLux's Avatar
Check all the ususal suspects? plug wires on tight? everything hooked up?
Sometimes its a simple overlooked think related to recent work.
xxxtreme22r's Avatar
last time I had that problem it was because I had put e3 spark plugs in my motor, did not like it one bit. went back to the old plugs, ran fine, put new plugs of same brand etc in ran fine. Check your plugs.
I doubt it was related to the belt change though. But since you were working in there also make sure all of your plug wires are tight, maybe you loosened one up when undoing the alternator somehow.
EDIT: DANG HighLux beat me to the plug wires. lol.
Old 09-21-2010, 04:39 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Hmmm........sounds suspiciously like a fuel pump/delivery issue. Just a possibility....
Old 09-21-2010, 04:43 PM
helidriver's Avatar
..... nobody went timing huh? maybe the heat changed something? heat fouled spark plugs were going to be my second guess.... fuel pump didn't think about that. CRAAP, let's hope it's spark plugs and worst case fuel filter.....
Old 09-21-2010, 04:52 PM
helidriver's Avatar
oh yeah, duh, 22re 5spd 4runner sr5. 270k. not throwing any warnings or dash lights.....
thook's Avatar
Maybe it's just "timing".....bahahaha! Okay, bad pun.
Check the easiest, first, I suppose.
Old 09-21-2010, 04:53 PM
thook's Avatar
BTW, how old is the pump?
Old 09-22-2010, 04:38 PM
helidriver's Avatar
don't know?!? I've had it since June 2006. IIIII"VVVvvee never replaced it?.....?
Old 09-22-2010, 05:43 PM
thook's Avatar
Oh. Any idea of mileage? Approx? Aver.? Nevertheless, the thing could be older than dirt, for all you know. Hmmm.....maybe time for a new pump. Can you test fuel pressure in any way?
Good thing it's a first gen....whew!
Old 09-22-2010, 05:56 PM
myyota's Avatar
I would replace the fuel filter, and would also consider replacing the fuel pump, chances are that its the original pump with a lot of miles on it.
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
Cbr954ryder
07-25-2015 06:32 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
redghost.308
California SoCal
07-16-2015 07:46 AM
Quick Reply: high RPM hesitation
