| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
HIGH OUTPUT ALTERNATOR, any problem if runin too high voltage??
__________________
------------------------------------- If it's not broken, it hasn't been modified enough. pickup 91 3.slo,along with "the money draining mod" PROJECT SAS UNDER CONSTRUCTION MY SAS BUILDUP AND MUCH MORE FONKY STUFF,check it out!! http://www.yotatech.com/f116/yet-ano...s-pics-155676/ |
#2 (permalink) |
Take it to AutoZone, Advance, Sears, etc and have both the battery and the alternator tested - it could be either one.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#3 (permalink) |
sounds to me like you need a new alternator anyway. a highout put alternator isnt going to put out more then 14 or so volts (the same that your current one should be putting out) its going to put out more amps. which will obviously help with the dimming headlights and other issues but from what you discribe with the voltage issues it sounds like your alternator or at least your voltage regulator is on its way out.
EDIT: tc is right it could be the battery too
__________________
~Brian GETTING FIXED 89 Ex-Cab 3.4 Conv. T100 Auto Tranny ~Phoenix 90 Ex-Cab 22re 5spd Came with parts truck. Doesnt run yet. 90 Reg Cab 22re 5spd Body Parts for the Phoenix 90 4runner 3.0 Auto (Wifes Toy) 92 4runner 3.0 Auto (Currently With Blown Engine) (New 3.4 Swap i think) |
#4 (permalink) |
High output means high current... not voltage. The stock 4R alternators are rather wimpy.
#5 (permalink) |
what "high output" lights are you running?
HO alts usually dont do as well at idle as OEMs do (tho they do put out more current at highter than idle) Where are you measuring the 12v? |
#6 (permalink) |
as said earlier voltage really has nothing to do with it. its how much amps he's drawing and how many amps his alt is cabable of producing.
__________________
#7 (permalink) |
ok first,ive rechecked today my voltage on batterie,and i got 14.4 on startup ,and 13.9 fan working,and 12.2 engine shut.so i guess im fine.i guess the wires upgrade really did somethin,i havent checked my system since.
__________________
#8 (permalink) |
okay dude you missed something somewhere so let me repeat it (VOLTAGE DOESNT MATTER) thats going to be the same on all cars no matter highoutput alternator or not. That is controlled by the voltage regulator in the alternator. Your voltage regulator is set to provide aprox 14.5 volts when in opperation and your battery will provide aprox 12 volts when alternator is not in opperation. this is once again going to always be the same on all 12V Cars and Trucks. A high output alternator puts out more amps then a regular alternator not more voltage.
What will tell you if you need a high output alternator is how many AMPS you are drawing and how many amps your alternator can produce. if your headlights are dim its probably because they cannot draw enough amps. Think of Voltage as Pressure in a water hose and think of amps as the flow of that hose. You can have all the pressure in the world but if you dont have a large enough flow to supply that pressure somewhere the pressure doesnt doo a hill of beans. The flow is limited by the pump (aka Alternator). You need to calculate your amperage draw with all your accessories on. then figure out how much your alternator can produce. you need to have an alternator that produces probably 1/4 more at least amps then you need inorder to keep your battery charged and everything working properly
__________________
~Brian GETTING FIXED 89 Ex-Cab 3.4 Conv. T100 Auto Tranny ~Phoenix 90 Ex-Cab 22re 5spd Came with parts truck. Doesnt run yet. 90 Reg Cab 22re 5spd Body Parts for the Phoenix 90 4runner 3.0 Auto (Wifes Toy) 92 4runner 3.0 Auto (Currently With Blown Engine) (New 3.4 Swap i think) Last edited by thefallman; 08-02-2007 at 09:59 PM. |
#9 (permalink) |
Staff
what he said. Modern single battery systems are 12v systems. Adding a higher output alternator will not affect your voltage. It will upgrade your amperage, which is what you want. Stock your alternator is putting out ~65 amps. If you are running extra aftermarket parts such as amps, stereo, lights, GPS, etc, you will want to upgrade to an 80amp+ unit.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#10 (permalink) |
Staff
btw if the AMP draw on the system is too high for the output of the alternator, it can cause an onver heating problem, or a fire. Its sorta like overloading an outlet at your house. Of course, thats what fuses are for, but you never want to get to the point where you are popping fuses.
__________________
#11 (permalink) | |
Quote:
he only way he would pop a fuse is if he had a grounded alternator with a fuse in the ground. because it would be drawing to much ground current trying to generate enough amps. but with the current setup he will just probably overheat the alt and blow it out. if hes drawing to many amps.
__________________
| Tags |
| 22re, alternator, highout, put |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| high output alternator for 1st gen 22re? | wifesaysimadumbass | Offroad Tech | 3 | 08-01-2006 06:52 AM |
| How to test a high output alternator | Bumpin' Yota | 86-95 Trucks & 4Runners | 3 | 03-21-2006 10:38 AM |
| New Alternator... High output... | Ducky | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 12-22-2004 07:05 PM |
| High Output alternator install. | dbikeman | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 04-14-2004 06:24 PM |
| What's a good high output alternator for a 2nd Gen? | JSB | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 10-23-2002 05:46 AM |
