High gear, low rpm = bad engine shake..
Old 11-07-2009, 04:18 PM
iCavity's Avatar
So i just changed my timing chain and cover because the old guides broke and sawed through the cover therefore mixing the oil and coolant, i finally got that all fixed, replaced the guides of course! xD
after i put it all together, i took it out for a drive, i noticed that [manual tranny] when i get to the high rpm's the car runs smoothly but if i changed gears too early and let the rpm drop the engine would shake really badly,
I'm not sure if its the timing or not. ><
what do you guys think?
thank you!
Old 11-07-2009, 04:40 PM
yoterr's Avatar
sounds timing related... have you had a timing light on her yet? or did you tune it by ear? and what year?!? is the dist about in the middle or all the way advanced or all the way retarded??
Old 11-07-2009, 04:41 PM
Ed H.'s Avatar
check it and find out, if it didnt do it before most likely its timing related, did you reset after you put it all back together.
Old 11-07-2009, 04:56 PM
iCavity's Avatar
Yeah, im about to get my hands on a timing gun, its not really centered jsut a little advanced. [:
Yeah it definitely didnt do it before, yeah i didnt mark anything so i had to reset everything T~T, what a bad choice..
Old 11-07-2009, 04:58 PM
jpmountainboy's Avatar
if it wasnt timing related id check your carrier bearing/motor & transfer case mounts.
Old 11-07-2009, 05:05 PM
iCavity's Avatar
Oh, sorry i forgot to mention the year and engine "yoterr"
xD
i have a '94 22RE PU
Old 11-07-2009, 06:21 PM
abecedarian's Avatar
What would you consider 'low rpm' and in which gears and how much throttle is it most pronounced?
5th gear @ 1000 RPM, and maybe up to 1500 or so will buck quite a bit if the throttle is down.
Old 11-07-2009, 09:55 PM
iCavity's Avatar
Hm... my truck doesnt have a tach, but ill try my best, xD
i havent gone that fast with it, it seems that the higher gear i go the more it shakes, feels like lack of power, but when i drove it was probably 2k-2.5k rpm on the 2nd or 3rd gear, but as the rpm builds up the engine becomes smoother and shakes less, or should i say hesitation,
could this be because of my timing is off?
sorry i dont know enough about about timing to know xD
P.S. if i were to time by ear is that with the terminals TE1 and E1 shorted?
thanks!
Old 11-07-2009, 11:44 PM
if you can't relate rpms without a tach, you cannot even start to guestimate timing by ear.
sorry.
zd92655
03-06-2022 12:58 PM
Ichneumon
09-27-2015 04:21 PM
noahstancik
07-10-2015 11:18 AM
saphirekosmos
06-22-2015 10:26 AM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: High gear, low rpm = bad engine shake..
