Hex bolt for manifold bolt - ok?
Old 11-02-2012, 10:02 AM
Josh_Br's Avatar
I have a 1990 Toyota pickup. The engine block and head are from a 1994. One exhaust manifold stud is missing (the front most bottom stud). Can I just use a hardened bolt with the same thread pattern, so long as it is the proper length?
Also, on the outside of the exhause manifold, part way down, there are three holes for bolts. One of these holes does have a bolt in it, but the other two do not. They appear to be places to attach brackets, etc, to. Is the absence of these two bolts hurting anything?
Thanks,
Josh
Old 11-02-2012, 10:59 AM
Replicant's Avatar
I used regular bolts for mine and havent had a problem. I just put lock washers on them.
Old 11-02-2012, 11:34 AM
SPARKS89's Avatar
Those three bolt holes on the outside of the exhaust manifold are for bolting the heat shield to it.
Old 11-02-2012, 11:36 AM
Josh_Br's Avatar
Awesome, thank you both very much.
RobotMoose
09-02-2015 05:53 AM
Dakotaneu
08-15-2015 07:24 AM
accuracy
08-06-2015 12:32 PM
whereAreMyPants
07-22-2015 03:32 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Hex bolt for manifold bolt - ok?
