Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Hesitation/stalling during acceleration
#2 (permalink) | |
Personal
Sales Rating: (0)
Quote:
__________________
Richard "Science by consensus... is not Science." Richard Harper -1988 '94 Toyota 4Runner V6 3L 158K miles 14mpg '85 Toyota 22rec 4WD SR5 LB PU 208K miles 18mpg '08 Honda Ridgeline RT 4.8K miles 16mpg '06 Honda Rincon ATV 410miles/65hrs 22 mpg |
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
Thanks for the reply, rdharper.
My truck doesn't have a tach so I'm not sure what its idling at, but it seems to be fine and hasn't changed at all since the problem started. I can leave it idling for a while and it never does it. the only time it does it at idle is right after coming down from higher speeds like the highway and that's pretty rare. Mostly the problem is when starting out in 1st or 2nd. Most of the time it just completely and instantly cuts out for a couple seconds then will come back to life just as quickly. It really feels like the engine just doesn't get any gas for a second or two. I never get a check engine light or any other idiot lights except on the rare occasion that it completely stalls out. Even when that happens, it usually fires right back up after a minute or two at most. Thanks again... |
#4 (permalink) |
Personal
Sales Rating: (0)
The TPS could explain your other symptoms, but not if the idling has not dropped to 500rpm or so.
I'd do a search on "hesitation" if you haven't already. I guess the next most probable cause might be fuel, fuel filter, fuel pressure etc. We'll see what others say.
__________________
#5 (permalink) |
Personal
Sales Rating: (0)
This is the check list for poor acceleration in the FM.
1. clutch 2. vacuum leaks-hose connections pcv, egr stays open 3. air filter 4. malfunction code-check engine light diagnostic codes 5. ignition spark- wires, distributor, coil, igniter 6. timing -5 degrees BTDC at idle (T and E1 short circuit) 7. fuel pressure- fuel pump, fuel filter, presure regulator (fuel pressure at cold start injector 33-38 psi with regulator unhooked, 27-31 psi with vacuum on regulator at idling. 8. check injectors 9. check spark plugs- plug gap 0.8mm, 0.031 in. 10. check EFI- air flow meter, water temp sensor, air temp sensor, throttle position sensor, injection signal(solenoid resistor) For sometimes stalls- check air flow meter |
#6 (permalink) |
Personal
Sales Rating: (0)
#7 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Thanks for the reply 4runnerx3. Its not so much "poor acceleration" as it is that the engine will just cut out occasionally and it usually happens when accelerating. Overall it accelerates just fine especially with the new dist cap, rotor, plugs and fuel filter that I've already replaced. Thanks for the list of other possibilities - I made some notes on them below:
Quote:
#8 (permalink) | |
Personal
Sales Rating: (0)
Quote:
#9 (permalink) |
Personal
Sales Rating: (0)
I'm curious too. I'm having what seems to be a hesitation problem with a newly adjusted TPS, no vacuum leaks, steady idle, almost new sparkplugs, wires, rotor, cap, and vacuum hoses. K&N air filter has been changed recently too.
Thought it might be the clutch so I adjusted the clutch pedal and loosened the pedal stop bolt. Mine has only been doing it in second gear when having the engine off for a few minutes. After driving it's fine.
__________________
1989 Toyota pickup 4x4 - 22re - Stock |
#10 (permalink) |
Personal
Sales Rating: (0)
pluggrd muffler or cat
#11 (permalink) |
Personal
Sales Rating: (3)
I hope since 5 years ago, he's got it figured out. Don't we have a :noob: smilie?
__________________
-Drew 1995 4Runner 4x4 | 3.4 5vz|a340f auto swap | Inchworm Tacoma Adapter | rf1a gear drive case | 4.10 | Lock Right rear | non ADD front swap | manual hubs | 1.5" 4Crawler BL | 31x10.5 Firestone Destination A/T | swaybars delete | shaved bumpstops |
#12 (permalink) |
Personal
Sales Rating: (0)
hesatation
i solved the problem you guys are having on my truck by changing the catilatic converter...i ended up doing a straight pipe from headers to muffler taking out the o2 sensor too. runs great now 22re motors last forever
#13 (permalink) |
Personal
Sales Rating: (0)
Is one of your injectors going out?
#14 (permalink) | |
Personal
Sales Rating: (0)
Quote:
You really ought to get it put back in. |
| Tags |
| 4runner, accelerating, acceleration, accelertation, engine, gear, hesitates, idles, low, pickup, po440, sputtering, stalling, stalls, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Stumbling/Hesitation during acceleration | Lifelongtoy | 86-95 Trucks & 4Runners | 58 | 11-30-2010 09:53 AM |
| hesitation and jerking during acceleration? | Jcod12 | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 04-02-2007 07:03 PM |
| Hesitation under heavy acceleration | rbh261 | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 03-22-2007 04:14 AM |
| Severe stumbling/hesitation and stalling (Longish post) | ChallengeTheSea | 86-95 Trucks & 4Runners | 21 | 02-03-2006 04:50 PM |
| hesitation or stumble during acceleration | toypr | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 11-15-2004 07:41 PM |
