help with wiring harness connectors!
Old 04-08-2015, 06:34 PM
Gamble_STi's Avatar
hey guys, i need a hand identifying a couple connectors on the engine harness. i cannot find what they connect to. engine is currently on a stand, so if they connect to something in the engine bay (looked there too) it would be awesome if someone could include pictures.
these are the only two i cant find a place for.
they could be routed to the wrong spot, they may go under the intake manifold. i just dont know. the sooner the better, would love to hear her run again soon! Thanks!
Old 04-08-2015, 07:06 PM
jbtvt's Avatar
INjectors?
Old 04-08-2015, 07:27 PM
rustypigeon's Avatar
What color are the wires going to those connectors?
Old 04-08-2015, 07:47 PM
Gamble_STi's Avatar
Green/white, and brown/black
Blue, and black with red or maybe brown stripe
Old 04-08-2015, 07:48 PM
Gamble_STi's Avatar
And they. Aren't injector wires, all four injectors are hooked up
Old 04-08-2015, 08:04 PM
Green/white and brown/black is EGR gas temp sensor.
...trying to find the other one...
Old 04-08-2015, 08:19 PM
Blue and black/red is the a/c idle-up vsv.
Old 04-09-2015, 03:47 AM
Gamble_STi's Avatar
Awesome! Could you possibly help me out just a little further? Anyone that could post pics of those two connector locations would be awesome.
Old 04-09-2015, 04:57 AM
A/C idle-up vsv....
EGR gas temp...
Old 04-09-2015, 05:55 AM
Gamble_STi's Avatar
So the get connects to a wire that is supposed to come out of the tube on the back of the intake manifold? And the other one goes to a third valve on the valve cover that I don't have. Sweet. Now I gotta find one.
As far as the connector to that tube on the back, I'll take a pic when I get home on lunch, I don't believe I have that either.
Old 04-09-2015, 06:06 AM
Staff
Terrys87's Avatar
That connector on the EGR is on California model trucks. It may be standard on the newer trucks. I had an 89 California truck with the sensor on the EGR. Never had a newer truck then a 92 so it may have been standard by 93 or up so I am not sure. Yours could possibly not have the connector for the sensor. Anoter way of knowing if it is a California truck is ti will say Cali on the hood sticker. A third way I have seen on early 89-95 trucks is a down stream O2 sensor behind the catalytic converter. Non California trucks will not have the sensor in the EGR or down stream O2 sensor.
When I first seen your thread, I could tell it was 89 or newer by the connectors. They changed several of them from the previous generation. If it was the old style I would know. Post your year and maybe some one with the same year could help as well. The newer each year the trucks got the more changes Toyota added.
Old 04-09-2015, 06:20 AM
Mine is a '94 non-California truck, so it must be standard on the later models.
Old 04-09-2015, 06:23 AM
What year is your ECU from Gamble?
Old 04-09-2015, 06:24 AM
Staff
Terrys87's Avatar
Thanks for letting me know. I have wondered if it was standard on the newer ones and have suspected it might be standard.
Old 04-09-2015, 07:18 AM
Gamble_STi's Avatar
As far as I know everything is the same year as the truck. 1993. I go on lunch in 45 minutes so I'll take some pictures as soon as I get home. Anyone have a spare a/c idle up valve laying around?
Old 04-09-2015, 10:35 AM
Gamble_STi's Avatar
Well got those pics. I don't think I have either of those things. Would the connector be on the harness if they didn't have the temp probe? Like one harness many trucks kinda thing? Or should I be buying that junk?
Old 04-09-2015, 12:00 PM
I can see the mount for an egr temp sensor in your picture. What is in the hole? Is there a plug or an open hole?
The a/c idle up vsv is only installed with a/c equipped trucks. Did you get an engine and components from a different vehicle?
Old 04-09-2015, 12:09 PM
Gamble_STi's Avatar
I'm sorry to be a pain In the ass here, but where do you see the port for the temp sensor? Could you circle it in my picture because I'm blind and stupid on this one.
As far as the ac, the truck has ac. Its just never worked. The tensioner for the ac belt is also missing, but I'm trying to make it work again.
Old 04-09-2015, 12:30 PM
This red circled area there is a rusty metal bracket. That is where the EGR temp sensor goes. Is there a hole on the top of yours or is it a solid metal plate?
Also, is this the same engine that came out of the truck or a different one?
Old 04-09-2015, 12:42 PM
Gamble_STi's Avatar
Its the engine that came with the truck. My dad owned it for 10 years. Sat for the last two and then I took it off his hands before he scrapped it.
Quick Reply: help with wiring harness connectors!
