Help with vacuum questions.....
Truck is a 1990 with a 96 3.4 put in. Has a cold air intake.
By the passenger fender is 2 vacuum hoses attached to a red and a blug plug. The hoses go down to the front axle where do I attach these?
There is a nipple of the front of the motor right above the 24 on the timing belt cover. What do these need to be attached to?
And finally, Where does the big hose off of the brake booster get rerouted too? It is still on the fire wall. I cant figure out where to move this too. I tried to attach a picture with arrows pointing to my questions but I can't get it to attach. I can send one if that will help.
Thanks for the response. I have since also figured out where to reroute the brake booster hose. Just need to find the nipple that screws into the motor right by the diagnostic connection.
kawazx636
10-06-2021 03:03 PM
zytra
01-24-2019 03:16 PM
