Help troubleshooting '91 22RE cruise control (vacuum switch?)
I've searched for the easy stuff first and looked over the FSM. The main switch activates and the "crusie" light comes on, the system just won't set and start maintaining speed. I checked the vacuum lines but am not sure how to test the vacuum switch. I've checked the clutch switch, and the brake switches. When running the "part A" diagnostics in the FSM, I see that the first two tests of the "set/coast" and "resume/accel" switches are blinking the way they are supposed to so now I'm stuck on step three which is testing the vacuum switch.
If someone could please explain this to me like i'm 5, that would be great. Or chime in with similar problems and fixes or any other insight. Maybe I'm overlooking something like the main relay or the CC ECU. Thank guys!
icentropy
07-14-2015 10:23 AM
