Help with Trouble codes - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-28-2007, 01:17 PM   #1 (permalink)
MRecio's Avatar
Hey guys I have a 94 4Runner 3.0 auto with 153K and I threw a code last night... After checking it this morning it is flashing code 24. then code 27. im not sure what code 24 is but i think code 27 is O2 sensor.... am i right? the light didnt come back on today when i drove it around... (seeing if I could get it to come up again.... It does seem the truck runs rich... if it sits and idles u can start to smell the fumes... and it is getting terrible gas mileage...
So i think i have to replace the 02 sensor. should I replace both? and how can i tell they are bad?
AND WHAT IS CODE 24 lol
__________________
94 4Runner 3.0 Auto 150K
"If you want to get there buy a Land Rover,
If you want to get back get a Yota"
MRecio is offline
Old 09-28-2007, 02:51 PM   #2 (permalink)
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
http://www.off-road.com/toyota/tech/codes/
Test the AFM before replacing anything. Look in the factory service manual on how to. The FSM links are posted on the main forum page.
__________________
Matthew
Context is everything....
Quote:
Originally Posted by abecedarian View Post
freckles, shmeckles... that was your acne reflecting on my pearlescent skin.
Get smacked....join chat!
http://www.yotatech.com/misc.php?do=flashchat
thook is offline
Old 09-28-2007, 05:38 PM   #3 (permalink)
MRecio's Avatar
I looked on the main page
http://www.toyotaparts.com/smg/main.php
that link is dead so i hope it wasnt the one you were talking about under it though thr is a link to download the manual for 10dollars... is this worth it? and is this what you were telling me to do to find out how to check my AFM... which has silicon around it as it has been taken apart before...()never noticed)
OK WAIT under the link it says for 97 and up.... so this isnt worth it for me as i have a 94..
__________________
MRecio is offline
Old 09-28-2007, 08:37 PM   #4 (permalink)
thook's Avatar
No, no...I mean look on the main forum page for "86-95 trucks and 4runners" where it says "Sticky: Links to FSM's".
Nevermind, though....here's the one you need....for free.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Look under "Engine", then look for VAM (volume airflow meter) for the 3vze. It has instructions for how to test the operation....whether or not it is bad in one or more areas. Or, if your just not getting a good connection, signal, etc. You'll need an inexpensive digital multimeter.
BTW, they have silicon around the seal from the factory, anyway. So, it may not have been messed with. But, you'd know better than I....I can't see it.
__________________
Matthew
thook is offline
Old 09-28-2007, 09:08 PM   #5 (permalink)
MRecio's Avatar
Ok i opened it up and the connections were bad.. they were just sitting there so i re soldered em but havent checked it with a meter yet but i started it and the truck idles much better but still run VERY rich... i am resetting the ECU to see if it was compensating for a bad AFM.... and see if resetting it will allow it to run normal. I will check it with a meter first thing in the morning tho.
If it still runs rich... do i have to replace te o2 sensor for the code 27? or can it be cleaned?
__________________
MRecio is offline
Old 09-28-2007, 09:14 PM   #6 (permalink)
thook's Avatar
You can try cleaning it. It wouldn't hurt. But, it may not be bad. That's why I suggested testing the AFM first. If it's running rich because of the AFM, then you may get an O2 signal just because of that. On the other hand, if the O2 sensor's not been replaced in a while, a whacky AFM may have pushed it over the edge causing it to go bad.
__________________
Matthew
thook is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
All sorts of trouble codes Please Help! mrboyertown 86-95 Trucks & 4Runners 7 10-13-2007 04:51 PM
OBDII Trouble Codes Bob_98SR5 Maintenance & Repair 0 01-14-2006 10:41 PM
trouble codes help now what?? 1987 street toy 95.5-2004 Tacomas & 96-2002 4Runners 0 12-05-2004 07:58 PM
Trouble. Reading Trouble Codes evilcow 95.5-2004 Tacomas & 96-2002 4Runners 3 10-02-2004 08:05 PM
checking trouble codes Robinhood150 Maintenance & Repair Archives 1 06-15-2002 01:58 PM
2009 InternetBrands, Inc.
