Help!! Tranny problems - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 08-17-2013, 08:02 PM   #1
4runneroutlaw's Avatar
So about two weeks ago I thought I'd be cool and go across a flooded creek...well long story short, bad idea.
My timing belt broke while I was out in the middle of it and pretty much everything got flooded.
I had my friend tow me home and I proceeded to tear into the engine (3.slow).
I replaced the timing belt and set the timing etc.
Flushed motor multiple times with new oil and added new K&N oil filter, also replaced intake gaskets and valve cover gaskets.
So now the motor starts and runs and all is well there and anyway I thought I was done and good to go...
Well I took off down the road and all was good for about 300 feet until the transmission quit doing anything at all...towed home again...
Apon inspection I noticed that my kickdown cable was loose at the transmission, in fact I can grab it about a foot and a half away from the throttle body and move it about 2 inches up or down and the cable kind of just bunches up at the throttle body instead of retracting back inside the tube...
Iv already drained the transmission fluid and am planning on taking the pan off and replacing the filter and pan gasket and putting fresh fluid in it.
Anyway my question is does the kick down cable have anything to do with it not pulling in any gear or do I have bigger problems??
4runneroutlaw is offline   Reply With Quote
85 Speedo drive question Dieselmann 84-85 Trucks & 4Runners 0 07-23-2015 10:10 AM
Pulling a Travel Trailer with my Yota shadowbirdie General Vehicle Related Topics (Non Year Related) 2 07-21-2015 11:38 PM
Leaking Rear Tranny Seal and Top Tranny Gasket Iceman4193 86-95 Trucks & 4Runners 3 07-15-2015 05:48 PM
Changed transmissions now reverse lights wont work madxman21 86-95 Trucks & 4Runners 2 07-09-2015 11:26 AM
4runner stalling in gear... Do this again please Jnkml 95.5-2004 Tacomas & 96-2002 4Runners 3 07-06-2015 02:20 PM
Tags
pinture, shemale
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
