Help with torquing Crankshaft Pulley Bolt in SLC
Old 05-08-2011, 07:07 PM
BDTB's Avatar
Is there anyone is Salt Lake who has a crankshaft pulley tool I can borrow? I tried to put together a makeshift tool with a 2X4 and a couple of bolts, but it gave out at about 120 ft/lbs. Dammit! This 5 hour timing belt job has extended into its second day, now.
'02 4runner 3.4L
Old 05-08-2011, 07:12 PM
Mr.Utah's Avatar
In Bountiful, but I dont have the tool.
Old 05-08-2011, 07:29 PM
Elton's Avatar
get a chunk of flat steel ?
Old 05-08-2011, 07:42 PM
The MAN's Avatar
is it a manual? if it is, you can put it into 5th gear and have someone stand on the brakes while you torque the bolt down
Old 05-08-2011, 07:43 PM
BDTB's Avatar
It's an automatic... I wish I knew how to weld, I would just whip one up.
Old 05-08-2011, 08:32 PM
Elton's Avatar
just take it to like a muffler shop they prob do it free
Old 05-08-2011, 08:41 PM
wormhole's Avatar
In bountiful as well but I don't have the tool.
Call Kurt at Cruiseroutfitters he might be able to help out or know of someone that can.
Old 05-08-2011, 09:10 PM
BDTB's Avatar
http://www.facebook.com/photo.php?fb...type=1&theater
Nope. Do over!
Old 05-09-2011, 05:46 AM
scope103's Avatar
Do you have an angle grinder?
https://www.yotatech.com/forums/f116...h-3vze-137934/
Old 05-09-2011, 09:18 AM
bugs1961's Avatar
Spend a couple of hours and make this tool:
https://www.yotatech.com/forums/f116...l-tool-186081/
It'll last forever and works great.
Old 05-11-2011, 08:48 PM
IDRUNNER's Avatar
Build the tool. I fought with mine and used a piece of plate alum. Used pulley off the harmonic dampener to get bolt pattern and bolted it on and blocked it to the frame. The crankshaft is not the problem its the cam bolts!!! Make " THE TOOL" it will keep you sane !!!
Old 05-11-2011, 10:07 PM
James Woods's Avatar
Well, I would have to look at it to make sure but with other cars, I have taken two 3/8 half inch extensions and placed a pry bar between the two to hold the crankshaft and then tightened the bolt, has worked every time so far.
Old 05-11-2011, 10:41 PM
yotarover's Avatar
use a impact gun.
andrewtexas123
07-06-2016 01:49 AM
romex1
08-10-2015 06:21 PM
rustym
08-07-2015 10:39 AM
TJWilly
07-31-2015 02:05 PM
Snort
07-09-2015 03:58 PM
Quick Reply: Help with torquing Crankshaft Pulley Bolt in SLC
