help-too much pressure
When i got home yesterday the engine light came on and when i stopped coolant was coming out of the cap. all the hoses were super pressurized. truck is running fine. no white smoke. thanks
oh yah 88 4runner v6
either you really overheated or you got a blown headgasket. most likely the HG. but to be sure wait till it cools down and then take the cap off and start the truck if it bubble its a blown HG. and you could do a compression test too see how bad its blown.
Probably HG. They often fail between the cylinder and a water jacket. That pumps exhaust pressure into the cooling system. As suggested, look for bubbles when you refill and if suspect, do a system pressure test.
Unlikely, unless you overheated and boiled your water, but worth a try.
Watch for smoke on start up. If you blow into the water jacket, you might not have any smoke during driving - but the radiator pressure will push water into the cylinder and sometimes cause smoke on start up.
ashamsuddin
17
01-13-2023 03:17 AM
charlie_fong
09-27-2015 10:06 PM
