Help!! Steering wheel locked & key wont work
94 ext cab 5 sp with 3.0. the key will not turn the cylinder to release the steering wheel. i have broken 1 key (the key came out) and dont want to damage the spare. need immediate help. cant start the truck or pull it home cuz of the steering need help need help need help!!
i have done that so many times i lost count. up and down, side to side. im thinking my next step is to punch out the ignition with a chisel and try to get it to turn that way. any other ideas before i do that??
pop off the ignition cover, their should be a small "button" on the bottom of the ignition. press that in and the ignition will slide out. then turn the ignition tab with a set of needle nose...
Sounds like it's just bound up a bit on the lock. Follow Jay's advice and turn the wheel there has been a time or two I can remember on other cars that I've had to really turn the wheel to get the lock to release.
I had this happen to me once, but not in my runner. I had to pull the wheel all the way to the left with both hand and have some one turn the key for me....real pain.
Good luck!!!!
Good luck!!!!
GreenLion
06-07-2021 10:49 AM
YotaGreenhorn
06-27-2015 07:00 AM
