help!!! starter,battery???wtf
Old 01-08-2008, 06:15 PM
bry-an's Avatar
ok well my runner has a hard time starting up after its been sitting for like 8 hours. I find it especially hard when I first start it in the morning and after work. it barely tunrs over , but no warning lights come on or anything. One time it would start at all and I got a jump and it was fine , so I am thinking the battery is screwed up not holding a charge or something. Also if I drive somewhere for about 5 min or so, after it barely starts, I can turn it off and it fires right up. seems to be only if it sits for a while.
should I check the water in the battery or is it just time for a new one?
thanks
bryan
Old 01-08-2008, 06:17 PM
toytech76's Avatar
buy a battery
Old 01-08-2008, 06:18 PM
Staff
DeathCougar's Avatar
Battery has a dead cell. it will allow the truck to be started right after shut off, but not after sitting for a bit. has happened to me a few times as well.
Old 01-08-2008, 06:19 PM
bigdaddy87547's Avatar
make sure connections to the battery are tight. take your battery to the parts store, test it, then go from there. "CORROSION KILLS BATTERIES"
Old 01-08-2008, 06:24 PM
camo31_10.50's Avatar
my '80 4x4pickup had the same problem...i replaced the battery cables and it ws good as new!...so check the cables...and watch for corrosion...
Old 01-08-2008, 07:32 PM
Jay351's Avatar
Clean the battery posts, check/add water to battery, check your cables.
Does this happen all the time or does it come and go?
When my battery went, it wouldn't start my truck even if I just turned it off.
Old 01-10-2008, 06:01 PM
bry-an's Avatar
it was the battery.... cold cranking amps were down to less than half and it went from a 12 volt to a 6.5 volt.... booo! funny thing was I tried to check the water for about an hour... then realized its a sealed battery.... AHAHAA
thanks for the help guys
Old 01-10-2008, 06:13 PM
Jay351's Avatar
Good to hear you got her fixed
Old 01-10-2008, 06:30 PM
Staff
i wins at teh internets again.
Old 01-10-2008, 06:33 PM
AlladdinSane's Avatar
HA!
Luke
justdifferentials
Just Differentials
06-13-2022 07:40 PM
Bourbonblues
12-15-2017 05:43 PM
Naween Zohab
11-10-2015 03:56 PM
pickle6415
10-19-2015 08:08 AM
Daenerysdad
10-01-2015 07:33 PM
Quick Reply: help!!! starter,battery???wtf
