help solve sputtering for me
Old 12-02-2012, 01:35 PM
Mickeybas's Avatar
Exclamation help solve sputtering for me
so my 92 toyota pick up sr5 225K allpro lift 33s starting sputtering on the way home from work yesterday and i have no clue what could be the cause of it, the truck has 225K on the sr5 and the truck has new heads with new valves when it suptters it only dose it at low rpms and when the rmps gets higher its fine the oil pressure is normal everything is normal. i think it is the vavles but i just want to make sure. also i was thinking of doing an oil change with the seaform stuff herd thats good for toyotas lol please help me out.
Old 12-02-2012, 01:46 PM
oldblue's Avatar
how do the plugs, wires, and cap/rotor look? ignition missfires are real common at low rpms with engine under slight load, such as being in 5th gear going up a very slight incline around 1500 rpm.
Old 12-02-2012, 02:00 PM
Mickeybas's Avatar
cap and rotor and brand new i guess i could check the plugs now. what else could it be you think?
Old 12-02-2012, 03:37 PM
TrikeKid's Avatar
Plugs and wires shoulda been done at the same time, cap and rotor can't do their job well with old plugs and wires in their way.
Mickeybas's Avatar
Turns out it was the cap and rotor i guess it wasnt a new cap and rotor lol thanks man
Gutted91
01-03-2020 09:48 AM
Firefightersink15
11-23-2015 10:32 PM
BK2TFUTURE
10-11-2015 08:42 PM
93RedKrawler
09-25-2015 04:03 AM
Gutted91
09-17-2015 05:44 PM
Quick Reply: help solve sputtering for me
