help please with Hard shifting auto tranny, 22re - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-07-2007, 08:50 PM   #1 (permalink)
trythis's Avatar
When I am driving with moderate throttle and let off the gas, the tranny will frequently slam out of gear. It can't be good for anything so I am hoping you ave suggestions.
It started after replacing my timing chain, which involved removing the head, or basically stripping everything down to the block and reassembling everything.
I am wondering if the transmission cable from the throttle body could cause this.
Thanks
__________________
89 DLX xtra cab 4x4 22re Auto with 210,000, 225 75R 15, Stock except, "new" 2000 toyota cd/radio, rear speakers hidden in the back seat, SR5 instrument cluster, factory clock. dead aftermarket cruise and some matching blue door pockets! New timing chain with Engine builders front end rebuild kit. Tokico RT trekmaster shocks <-like them.
I found the turtle in my yard, after mowing over it and it was fine! Old toyota trucks are like turtles: slow, steady and durable.
trythis is offline
Old 05-07-2007, 09:03 PM   #2 (permalink)
toyaholic's Avatar
the cable has a little swadge that sits inside the rubber boot around the cable and at fully open throttle you are suppose to only see .5 to 1 mm of the swadge exposed from the boot. i don't have my manual right now but it might be in the 93 fsm posted on here. either way i really don't think that that is it unless you really moved the adjusting nuts a whole lot. mine was a good bit off after my rebuild and it really didn't make any noticeable difference.
__________________
-89 deluxe 4runner 22re/A340H
-85 extended cab 4x4 with 22r/G52
-89 corolla 4af
toyaholic is offline
Old 05-07-2007, 09:07 PM   #3 (permalink)
toyaholic's Avatar
http://personal.utulsa.edu/~nathan-b...32prelimin.pdf
here it is. i guess it could possibly be the problem. good luck. check for diagnostic codes and do a manual shift test.
__________________
-89 corolla 4af
Old 05-08-2007, 06:13 PM   #4 (permalink)
4runnerx3's Avatar
The throttle cable adjustment is important. The other end of it goes inside the valve body on the tranny. If it's out of adjustment, you can have harsh shifting, or strong jerking from park to drive, and since it controls pressure inside the tranny, it can cause it to drop in and out of gear.
4runnerx3 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Auto-Tranny Shifting hard into Drive Tdubbs05 86-95 Trucks & 4Runners 25 03-27-2007 09:12 AM
Tranny shifting hard! crbocaj125 95.5-2004 Tacomas & 96-2002 4Runners 1 06-02-2006 05:00 PM
auto tranny not shifting into overdrive USAtruck6 95.5-2004 Tacomas & 96-2002 4Runners 7 10-15-2005 05:34 PM
Auto Trans Noise/Slipping/Hard Shifting - Dealer says wrong ATF used lv4runner 95.5-2004 Tacomas & 96-2002 4Runners 15 01-19-2005 07:08 PM
tranny is shifting hard rabidbeaverbaby Maintenance & Repair Archives 4 07-23-2003 08:41 PM
2009 InternetBrands, Inc.
