help please
help please
well i switched the bulbs behind my gauge cluster and now my blinkers wont work and second of all i broke my dimmer switch need help in which direction to look in
Staff
In my area a combo switch runs about $40 from the boneyard. I would suggest getting one from there and before putting it in, clean the contacts on the switch assembly to head off the problem of bright lights not working. The contacts just need a quick cleaning. I have it listed on my 88 Runner build thread on the first page. You will need to rent a wheel puller from a parts store.
or bring a friend.loosen steering wheel nut a few turns, one guy pulls up on wheel as hard as possible and the other guy wacks the nut with a hammer.should pop up easily.
You'd hit the steering column with a hammer just to save $20? http://www.autozone.com/autozone/acc...uller/_/N-2652 (Actually, to save nothing; I think Autozone loans these out for free. )
Please, easy on the hammering. The steering column is designed to "telescope" in a collision, and you don't want to get that mis-set.
You need a rheostat (Toyota part name) no need to pull steering wheel, but if you can find a used one it will save you money. They're spendy new from dealer.
Not sure what year your pickup is but judging by your avatar I think this is the part. It's $111 from tituswilltoyota.com, but it's used on a few models I'd check the classifieds here for a part out. Part 84119‑04010 (RHEOSTAT, LIGHT CONTROL) was found on the following models:
Date range Model Frames/Options Found in diagram
02/1992-12/1994 TOYOTA 4RUNNER TRUCK RN101,110,VZN100,110 84-01: SWITCH & RELAY
01/1995-08/2004 TOYOTA TACOMA RZN161,171,VZN160,170 84-01: SWITCH & RELAY 09/1991-12/1994 TOYOTA 4RUNNER TRUCK RN80,90 84-01: SWITCH & RELAY
01/1995-08/2004 TOYOTA TACOMA RZN140,150,19*,VZN150,195
If it's an 89 that's better lots of interchange on that part.
Part 84119‑32090 (RHEOSTAT, LIGHT CONTROL) was found on the following models:
08/1987-05/1992 TOYOTA COROLLA AE92,95 84-01: SWITCH & RELAY
08/1987-08/1992 TOYOTA COROLLA AE92 84-01: SWITCH & RELAY
09/1990-07/1993 TOYOTA COROLLA AE95 84-01: SWITCH & RELAY
08/1987-07/1989 TOYOTA CELICA ST16* 84-01: SWITCH & RELAY
08/1988-05/1991 TOYOTA CAMRY SV2*,VZV21 84-01: SWITCH & RELAY
07/1988-08/1991 TOYOTA CAMRY SV2*,VZV21 84-01: SWITCH & RELAY
06/1989-06/1991 LEXUS ES250 VZV21 84-01: SWITCH & RELAY
08/1988-10/1995 TOYOTA 4RUNNER TRUCK RN10*,110,13*,VZN10*,110,13* 84-01: SWITCH & RELAY 11/1995-07/2002 TOYOTA 4RUNNER RZN18*,VZN18* 84-01: SWITCH & RELAY
08/1988-10/1995 TOYOTA 4RUNNER TRUCK RN8*,90,12*,VZN85,9*,VZN120 84-01: SWITCH & RELAY 08/1992-06/1998 TOYOTA T100 RCK10,VCK1*,2*
