Help! Passenger window issue
Old 06-03-2009, 08:38 PM
seandog's Avatar
I have an 86 4Runner. The passenger window will not go up from either driver or passenger switch. I tested the motor and it is good. I checked the voltage on the drivers switch and I'm only getting a voltage drop for the driver's window(the one that's working) and not the passenger switch.
Is it my relay that has a problem or maybe a bad wire??? Thanks, I've been working on this a while with no luck.
Any ideas???
Old 06-03-2009, 11:22 PM
AiNoKeA_808's Avatar
could be a relay if you can't roll your passenger window up with either switches.
jasonty
41
12-23-2018 01:00 PM
coreyedwards7611
01-16-2016 06:38 PM
icentropy
07-14-2015 10:23 AM
Johntom240
7
07-13-2015 12:18 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: Help! Passenger window issue
