Help with OBD codes
Old 04-18-2008, 09:31 AM
mikilu88's Avatar
Help with OBD codes
My car (1989 Toyota 4runner 22rec) has had the obd codes 25 and 26 on for a while. I've read all of the reason why but i would like some input before i start buying parts. If i reset the ecu (take of the ground from the battery) the check engine light goes on again only when i am highway driving(like after 3-5 min of going 60 on the freeway).
Well... any info on the subject is welcome!! Thanks!
This is the webpage i've got the codes off from.
http://www.off-road.com/toyota/tech/codes/index.html
Old 04-18-2008, 09:51 AM
toytech76's Avatar
Those are lean/rich codes. Could be due to a bad o2 sensor, bad tune up, tight valves, vac leak. Do some diag before throwing parts at it
moparbay
10-06-2015 09:24 AM
bradahman
10-01-2015 09:24 AM
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
Draven023
09-26-2015 12:41 PM
Quick Reply: Help with OBD codes
