Help a Newbie: General Updating To-Do List
Hi,
I just purchased an '86 4x4 pickup and want to update everything that may potentially be a larger issue for a 30-year old truck. The motor seems solid, with a few updates such as plug wires, etc.
However, the suspension feels spent, so I'm assuming it hasn't had much TLC over the years. I want to ensure that I'm not riding in a death trap, but I'm far from a mechanic, so just need some guidance on where to begin. Perhaps, what to look for? I'm hearing some loud pops/ screeching at sharp turns and low speeds. Assuming the balls joints need updating from what I could find here.
Is there a general priority list that I could run down? Appreciate all of the advice anyone can provide!
Start here: http://web.archive.org/web/201208120...buchanan/93fsm
Run through all the items in the maintenance schedule. In your case, follow the links to suspension, and run the tests on the ball joints.
If you're willing to use "deathtrap" and "far from a mechanic" in the same sentence, you should consider dropping a few bucks on someone who REALLY is a mechanic. He doesn't have to do the work (replacing ball joints isn't that tough), but you'll feel better having someone tell you where you've GOT to start.
Like everyone else mentioned, look through the service manual and just start checking things off. If you don't have any history on the timing chain, that's a big one to cross off in the not so distant future, otherwise, do what you can afford, track everything so you can start doing all of this stuff on the regular.
Oh and while you're underneath looking at the suspension, might be a good time to invest an a grease pump and lube up all the points along the driveline. Do some digging and make sure you use the correct grease since there seems to be much debate. May also want to check the rear end while under there as well.
Good luck!
Hi,
wally
surf4life
11-28-2015 03:32 PM
