Help. Need to know if an engine swap will work! - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 07-13-2013, 10:36 AM   #1
cregs1119's Avatar
Okay so here's the deal. I need to know if a 5sfe will bolt onto a tranny for a 92 tranny. I've been searching and can't find anything that says yea or no. I know it's a motor that sits sideways but in some applications it runs awd vehicles. Can anyone lend any helpful info?
cregs1119 is offline   Reply With Quote
Old 07-13-2013, 10:51 AM   #2
bone collector's Avatar
which 92 tranny? auto or manual? are you taking out a 4 cyl or a 6 cyl?
bone collector is offline   Reply With Quote
Old 07-13-2013, 10:53 AM   #3
cregs1119's Avatar
The motor that was in the 92 is a 3vz.
Old 07-13-2013, 10:53 AM   #4
cregs1119's Avatar
Sorry and its a standard tranny
Old 07-13-2013, 11:43 AM   #5
cregs1119's Avatar
It looks like the tranny still bolts to the rear of the motor, it's just whether the bolt pattern will match up
Old 07-13-2013, 11:48 AM   #6
google it..... will your input shaft and splines work with the motor?? bolt pattern and starter work??? you will probably need an adapter plate at the minimum. do some research... read, search, read some more. it probably is too costly and has too many disadvantages for it to become a popular swap like the 5vze or 7mge.
Old 07-13-2013, 11:54 AM   #7
not only that. you will probably have to get new motor mounts welded to the frame. I am assuming you have a 4wd truck based on your avatar. with the front drive shaft hit the oil pan?? what electronics will you have to switch over?? your 92 truck has OBD I computer but Im willing to bet the 5sfe is OBD II (although im not for certain) so how much wiring and computer work will you have to do?? there are probably a million other details I am forgetting about right now. I am in no way telling you not to do this, im just trying to get you prepared for the long road ahead. Google will definitely be you friend. good luck!
Old 07-13-2013, 11:54 AM   #8
cregs1119's Avatar
I have been researching all morning. I can't find anything where anyone has done that sort if swap. I don't know if I could possibly just be typing in the wrong search words or what but I haven't been able to find what I'm looking for.
Old 07-13-2013, 11:57 AM   #9
cregs1119's Avatar
Yea well the frame I have is actually for an 80 model. So motor mounts will definitely have to be rewelded. The guy who is selling the motor is scrapping the car and will give me the ECM and whatever else I need to make the motor run.
Old 07-14-2013, 06:10 PM   #10
cregs1119's Avatar
So that motor swap will not work. Nothing I saw will accommodate a 4 wheel drive transmission.
Need help on 88 4runner no idle stalls JF9243176 86-95 Trucks & 4Runners 13 12-11-2016 07:04 AM
Help me Finish My Swap! Goddamnboh 3.4 Swaps 12 05-11-2016 10:22 PM
22re Overheats when climbing hills noahstancik 86-95 Trucks & 4Runners 19 07-10-2015 12:18 PM
Idle issues Alex Bessinger 86-95 Trucks & 4Runners 4 06-28-2015 11:05 AM
95 tacoma wont start... what did i do?? gog1968 Newbie Tech Section 2 06-22-2015 06:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
