Help me pick out a horn setup for the pickup....
Since I have the buick 3800 swap..I dont ahve a horn setup. I think legally i need to have a horn, and i just plain old want one. Im looking for somethnig I can hook up pretty easily, is loud as a mother and is cheap. A lot to want eh? Anybody know anything about this kit?
http://store.summitracing.com/partde...5&autoview=sku
If you know of another good kit, that is similar..please post up! I NEED A HORN
Assuming that that's the same one under my hood, I don't like it. The PO installed the horn (Two little air horns with a Hella stamp on the resevoir). It is too high pitched for me, loud, but high pitched. It seems to get lost at freeway speed too.
There was one my ex had me install on her Passport. It was from Harbor Freight and shaped like a snail shell. All I did was tap into the original horn and mount it. That thing was loud and deep. I can't seem to find it anymore...
EDIT: http://www.shop.com/125dB_ADD_A_HORN...27694-p!.shtml
And anything over 120dB is capable of almost instantly causing hearing damage.
maybe ya didnt see where I said cheap? Im probably just gonna pick somethnig up tomorrow at the local car parts store. It will be loud enough. Comes with a small compressor and is like 118 DB
dude you gotta get the horn that the General Lee had. there is nothin more bad arse than that horn... or a 5 dollar air horn from wal-mart. you could lean out the window and press the little button every time somebody cuts you off
I got some wolo maxihorns from pepboys for like 20 bucks. Loud enough and work good too.
But my real passion is finally installing the general lee horn, screw being a northerner I like that horn!
I think this ones cool too http://www.carcoverkingdom.com/audio...ycharge_455.au
I want a freight train horn on mine, no seriously, kinda like this one
http://www.dieselairhorns.com/sounds/S-5t%20Ed%20K.mp3
i think the keyword here is CHEAP. go to a junk yard and get the dual tones off any german car: audi, vw, bmw. simple to hook up and a good loud tone, not that beep-beep that asian cars usually have. if you dont have a relay set up then grab that too while you're there.
Just get some from harbor freight or kragen or wherever for like $20. Then just wire a switch into the car somewhere since you have no horn button.
I have 2 sets of the Wolo air horns, which equals 2 compressors and 4 horns. LOUD as hell. Not quite train loud but it suits me fine for the price.
http://cgi.ebay.com/NEW-WOLO-GOD-FAT...QQcmdZViewItem
But seriously, I have a Wolo airhorn and it's awesome. The end of the meepmeep!
LOL I was really looking for freight train horns and ran across this video of one:
http://www.break.com/index/train_horn_scare_prank.html
I pulled a Hella OEM low-tone (there are 2 horns in the Mercedes: high/low) horn out of a Mercedes E-Class. Plug and play, just had to run a ground wire, its just a tiny bit bigger than the stock horn and it bolted in the factory location. Cost: free.
Location: Houston (home), Atlanta (school), Cincinnati (work)
jimkoz26
08-05-2015 03:15 PM
Bflo338
07-21-2015 07:28 AM
WTB[MidAtl]: WTB: 89-95 radio brackets/standard cab carpet 2wd
mtb_taco
07-15-2015 08:36 AM
