Help me for the love of god!!!!
Old 07-26-2015, 02:24 PM
Dakotaneu's Avatar
so i have a 4 cylinder 22re engine and about 8 months ago my water pump went up during the worst time, so in order to fix it i had to drive the car 7 miles without a waster pump to a heated garage to fix it basically screwing my motor. so about 8 weeks ago i started to have oil show up in the coolant. my first thought was that the timing chain had ate through the timing guide, which was correct, but, it did not eat through the timing cover it self, so i replaced the head gasket, and while i was at it i did a EGR delete, port and polished the cylinder head, made a custom kinda 2.5 inch axle dump using the original exhaust header and replaced every gasket i could get my hands on. i stripped the motor down to the block and about 29 hours ago i started it up, i had my dad help me set the timing, the car idles smooth but when you pull the throttle from what im guessing at 1500 or so rpm the engine surges and kinda hits a rev limiter. i can not for the life of me figure out what in the living hell is going on!
Old 07-26-2015, 02:42 PM
superex87's Avatar
Well how much experience do you have porting and polishing 22re heads? That may have been a mistake. No tach?
Did you jump the diagnostic connector to set the timing?
Check afm hose for cracks and or tears.
Old 07-26-2015, 05:55 PM
totally a bro
Staff
vital22re's Avatar
sounds like the tps sensor is wet or not properly adjusted.
Old 07-27-2015, 12:03 AM
wyoming9's Avatar
Red face
It could be so many things
Get the cam sprocket off a tooth
distributor off or timing set with the jumper not installed
TE1 to E1 Jumped
What year early year Vacuum Advance ??
Which means pretty much the timing is not set.
I would look at timing first
Just bad luck the fuel filter is full of rust restricting volume
ashamsuddin
17
01-13-2023 03:17 AM
83yotastockR
11
11-10-2015 06:54 AM
JookUpVandetti
09-30-2015 08:58 AM
Toys4parts
09-26-2015 01:56 PM
Project90
09-24-2015 11:40 PM
Quick Reply: Help me for the love of god!!!!
