Help me identify this transmission leak...
1989 RWD 22r pick-up, 4-speed manual.
Before swapping in fresh, expensive Amsoil 75W-90, I want to identify the source of this slow leak. The tranny is wet all over, but I think the oil is coming from this line/fitting. What is this? Speedometer cable?
I'm obviously not a transmission guy; the tranny appears to be two separate pieces separated by gaskets. One half butted up against the engine (the half with visible drain/fill bolts), the other half below the gear-shift. Is the rear portion the transfer case? I thought transfer cases were used only in 4WD applications. If these are two separate, sealed units, how do I change the oil in the back part?
Lastly, is the shifter turret sealed off from the rest of the transmission? The turret reservoir in my old Mazda Miata would dry up and require an oil refill every few years.
Yes speedo.
You have bellhousing....houses clutch...up against motor...than gearbox after.
Shifter "turret" is connected to trans...you can even fill it through the shifter hole if you remove shifter...easier than squeezing it up to the fill hole with a bottle and hose.
ONly need to fill via oil fill hole in side of trans or shifter...no secret chambers....lol
The O-ring doesn't technically seal the cable; it stretches around a separate housing to which the speedo gear is connected. I attempted to replace the O-ring, but the housing would not fit back into the transmission. The original looked undamaged, so I reused it and reinstalled everything with a lot of heavy grease. Looking back, I don't think it was ever leaking at the speedo cable, anyway.
The inner-most shifter boot (part no. 33555-35040) was shredded and the bolts holding down the shifter retainer plate were loose enough to turn with my fingers. The gasket (part no. 33584-60010) was completely saturated with oil. Oil was free to escape in both places and drip down from the top of the transmission, including on and around the speedo cable housing.
To get a socket on the two rear retainer plate bolts (to apply actual torque), I had to drill through the floorboard. Stupid design, in my opinion, but the base of the shifter boot still covers/seals the new, larger opening.
The upper and lower OEM shifter bushings looked new, so I reused them as well.
How did you replace part #33555-35040?
How did you install the shifter boot (33555-35040) on the shifter? The lower end looks welded together and the upper parts look like they have been epoxied together and have too large of a diameter to slip the boot easily over.
Thanks for any advice
Lube the new boot and the shifter with WD-40 and pull the shifter thru after removing the shift knob.
If the boot is lubed up good, you can pull it thru without damaging the rubber boot.
FS[NorAtl]: FS: NYC 1987 4x4 22RE Engine and Auto Trans
TransAmBandit
09-20-2015 06:08 PM
kelly1450
09-02-2015 12:29 PM
