Help me guess this fluid. I dont think its oil
The fluid is a dark rusty brown it is leaking from very slow but leaking
right under in the middle of the big crossmember at the position you place you jack
my car is going through violent squeling that just started and im trying to fix it also the leak is coming from the middle but more towards the passenger side
What does it smell like?
It could be:
Motor oil (will smell like gas)
Power steering leak (should be ATF fluid)
Or your front differential (oil should smell pretty bad)
It could be:
Low Power Steering fluid makes more of a groan than a squeal...Unless it's really low, then you can hear the pump chatter. My 4Runner drinks power steering fluid like a fish does water.
Rusty brown, kinda slick, smells burnt? Trans fluid, power steering is leaking or the trans.
Go get some brakleen and clean it all off then watch for where it comes from.
under which crossmember? I've got a few under mine.
is the leaking fluid thick, thin, slick, sticky? ... have a sulfur smell?
and is it auto, manual? scratchy / squeal could be torque converter or clutch throwout / release bearing.
hard to diagnose sounds heard from keystrokes on someone else's computer.
jasonty
41
12-23-2018 01:00 PM
Toyvana
07-29-2015 10:47 PM
