Help!!!!! me fix my leaking problem...
I'm trying to fix my leak, so I replaced the transmission seals, and am gunna change the rear main seal, but I think what is leaking is above the transmission...What is the part in the picture below and could I take it off and make a new gasket for it? Could this be causing my leak?
clos up..
It's right above the clutch etc...
clos up..
No idk what it is lol it could be, that would suck. I'll take a look under there a little closer when I can get out there and work on it again. If it was that, I probably won't be able to fix that till next summer...oh well it's just a tiny leak, and I don't notice any oil being gone when I check it.
Anyone know what this cover is for, and if it could cause the leak?
Thats what the plate thing is too? Not the silver pipe, the plate that is bolted on above it? If so, thats not the leak?
that plate is a royal pita when the head is still the truck. after rebuilding my engine, first time putting coolant back in, it leaked from there, almost impossible to get to with the tranny in place.
if you can do it now while the tranny is out , seal it up good.
make sure its coolant that your leaking though. if its oil, which is kinda what it looks like, it could be from the valve cover gasket at the back leaking oil down?
Thanks for the help guys! I'm pretty sure it is the back of the valve cover leaking...anyone had to deal with this? Is it a pita?
I've never seen this half moon plug lol, I'll probably try and fix it next summer as I'm leaving for Vegas (school) on thursday and have no time...thanks for all the help guys.
jasonty
41
12-23-2018 01:00 PM
polo451
13
11-20-2016 07:49 PM
