Help me Figure this out front sus Spending spree
Well I am at a point where I want to replace my front suspension. I have too much slop at the wheel, right side inner tire always eats up super fast. Upper ball joints creak and pop under full lock occasionally and sometimes just pulling into a parking lot at a different grade.
Anyway I've already replaced the lower ball joints last year. I am somewhat out of the loop and at this point of my day of internet shopping for the better half, tired.
I'm curious where you bought em', and what brand upper ball joints. My new lower balls (heh) are 777.
Have any of you guys just bought new suspension arms with the rubber already in them? I want to by them open the box and hopefully have already taken my truck apart to just swap em.
Next steering. What should I buy? what have you done? I want a new truck feel. Shes old, beat a little, and tired around all four corners, so I need to rubber and cant phatom spending $650 plus on rubber wo getting the front in order.
Thanks man. Where did you buy your parts.
I'd like to buy quality parts at the best price (don't we all). I'm definitely getting tie rod ends, upper ball joints. I already replaced my idler arm. I'm interested in buying new or reconditioned A arms that have new rubber.
I am grown custom to using a brand called AutoExtra.. They come from a privately owned parts store here in WV. They hold a outstanding warranty and I can just swap them out in store if needed.
Not trying to tell you what to do but you should change all four Balljoints at the same time. Even if the lowers are only a year old I'd still recommend you changing them. But to tune up the steering and suspension then you need to replace the following things to obtain the new truck feel.
Upper Balljoints
Lower Balljoints
Idler arm
Pitman arm
Inner TieRods
Outer TieRods
Shocks
Replacing all that and obtaining a front end alignment should put you were you wanna be. Now you may or may not need to replace the control arm bushings. You can inspect them and go from there.
There's several brands of parts out there. Try to buy the ones that have a good warranty and grease fittings. I do suggest staying away from Moog as our lil toys don't like them. I will admit I was forced to use a Moog Idler arm on my T100.
Upper Balljoints
Lower Balljoints
Idler arm
Pitman arm
Inner TieRods
Outer TieRods
Shocks
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
crashburnoveride
07-10-2015 06:39 AM
