Help me determing if i need new Wheel bearings with You Tube
hi
im trying to figure if i need to replace my wheel bearings check out this video to see if there is too much play
one thing i will say was i suppose to do the shake test when only one tire is jacked up because i did it when they both were jacked up
[YOUTUBE]http://www.youtube.com/watch?v=YmI0bjs8j-k[/YOUTUBE]
im checking this becuause my truck is making some nasty noises
You need to set the camera up under the front looking at the suspension and then move the tire. I thought that was what you were doing in the end, but you gave up.
From what I've seen, I can't tell what's going on. I am thinking idler arm, or tie rod ends, etc, but can't tell for sure without an underneath view.
What does the noise sound like?
No you look fine. You should grab the wheel from the top and bottom only. This will show bad wheel bearings. The slop you are seeing are bad tie rod ends or you are just turning the steering wheel. Make sure the wheel is locked.
your on the right path posting videos.. im wure we can help you with this.. yotatech loves problems with videos and pictures ... worked with all my problems!!
and i got 3 old toyotas so i gots lots of problems
Exactly.
If it hasn't been done in a while, if the bearings turn out to be good once you get a look at them, it would still be of benefit to repack them. Plus, even if the bearings did wobble, grease may be all they need. I just repacked mine a couple of weeks ago. After long, long neglect, the Koyos were still pristine looking.
