Help ID Part for me?
Old 07-13-2012, 04:05 AM
ScottieD369's Avatar
I am looking for this. What is the part # and where can I purchase it?
Yes I found the pic from a different thread but nobody said a part #?
All I know is it's a: Diaphram Sub Assy, Cooler; Diaphram Sub Assy, Idle Up
I have a 1986 Toyota 4 Runner SR5 2.4 22RE EFI non turbo
I've just been trying to replace what is missing!
Old 07-13-2012, 05:09 AM
waskillywabbit's Avatar
Dealer. Junkyard. eBay.
:wabbit2:
Old 07-13-2012, 05:11 AM
actually it's dealer discontinued and not too many good junkyards around by me and not much luck on Ebay atm ok I understand but I still need a part #
Old 07-13-2012, 05:48 AM
angrybob's Avatar
A/C Idle-up valve.
Click here and scroll through the next couple of pix.
Does the A/C not work? Might have been removed for that reason.
Old 07-13-2012, 05:53 AM
MudHippy's Avatar
88031A Diaphragm Sub-assy, Idle-up Actuator 88606-35020
And it's available still, not discontinued.
Old 07-13-2012, 06:13 AM
Hey thanks! and no I don't have A/C
Old 07-13-2012, 06:30 AM
btw I thought it was disc bc that I when I originally went there they said that they couldn't help me with my issues. Most of the time I gave them part #'s they said that they didn't carry them no more and I was forced to use the internet to get them. This time they said they can get it and I had to order it so it's better to get off the internet anyway and save $5 Although no luck on Ebay
Old 07-13-2012, 11:06 AM
TNRabbit's Avatar
If you don't have a c you don't need it...
Old 07-13-2012, 01:34 PM
combatcarl's Avatar
Now my buddy's 22re had that too, but was connected to the PS pump idle up. He had no AC, either. I don't have AC, but my PS pump idle up just has a plug in that hole, and the lines run into the plenum and throttle body...which way is right?
Old 07-14-2012, 01:00 AM
myyota's Avatar
Go on ebay and look for a seller that has alot of toyota parts listed, then email them and tell them what you need, and they will probably have it.
I needed a part for my 86 4Runner that I couldn`t find, so I emailed one of the part sellers on ebay and they had what I needed, they just didn`t have listed in there ebay store.
Old 07-14-2012, 07:37 PM
abecedarian's Avatar
PM DeathCougar
Old 07-24-2012, 10:09 PM
I have found most of the time searching for parts even when the dealer won't get you can still find here ____>
http://www.villagetoyotaparts.com/
also
http://www.autopartswarehouse.com/toyota~rep.html
Old 07-24-2012, 10:13 PM
Really? Because yeah some people still have those things even though they have no ac but yes it could have been pulled out for more horsepower from a previous owner and mine just stripped out completely. So if your saying that vacuum line and switch is for the ac system then how does it work?
05-20-2016 10:27 AM
88sasturbotoy
08-11-2015 01:56 AM
Fundy Rider
07-16-2015 01:35 AM
akaphilly
07-09-2015 02:34 PM
Quick Reply: Help ID Part for me?
