help ID this noise/problem plz
in 4wd @ highway speeds when i let off the gas pedal i hear a rattle/vibration that sounds similar to the engine but slightly louder and it seems to be coming from around the right front tire or thereabouts. i had a peak at the CV boots and they are not torn but i know that isn't always necessary to indicate a CV problem. i didn't check the u-joints on the drive shaft yet, but that is my next theory. anything else that might be causing this sound? thanks in advance.
U-Joint was my first thought...
how many miles on them that you're aware of? when's the last time you greased them?
for $15 and maybe 30 minutes an end, if you're unsure about their condition, I'd replace them anyway; seen Yotas&Jellos's thread recently with the broken flange?
Oh, and LMAO at your sig; pig and elephant DNA just wont splice, bahahaha, that was a funny episode
Um...Brendan, check out this thread....
https://www.yotatech.com/forums/f116...lay-ok-162143/
Be sure to read the write up in the link provided. See if anything with that or the thread itself sounds familiar.
Thanks, this helped me.
still not sure what the cause is. i drove around to listen to it some more and it sounds kinda like an engine brake, just not nearly as loud and it only lasts for 2-3 seconds after i let off the gas pedal in 4wd
FS[PacNorWest]: Really Nice Truck on WA craigslist
Esibnitsud
07-21-2015 08:51 AM
