!!!!!! HELP!!!!!!! I need help please
Old 11-20-2012, 02:47 PM
Kurtis Bernard Klein's Avatar
1987 Toyota pick up 2wd auto with OD
So this summer I took my block and head to get rebuilt this is where it starts.
so had all the rebuilt new timing chain ,cover ext all that was done so it was as close to new as possible .
Here’s what I bought new
.offy dual plan intake manifold
.Weber 32/36 carb
.1 inch carb spacer
.hole new ignition system other then the coil
.k&n air filter
From what I can think of right now that’s all
But my issue is that its starts and it idles fine. I can step on it and it sounds and works fine.
as soon as I put it in drive the idle drops doesn’t die most of the time but try to drive it starts reallllllly slow and I have to have it to the floor . Then it just lets go and it will go faster but no fast then 50ish km.
All I know that I've done wrong this far is I need an 81 water outlet for the offy intake.
Oo and all the oil's are at perfect level
I miss my truck very much and any help would be nice.
Old 11-20-2012, 03:12 PM
wii_tarded's Avatar
Have you had the trans. checked? May not be the engine at all.
Old 11-21-2012, 05:16 AM
well the trans work perfect befor we did this build i drove 1200km home then took it all apart i never had a trans problem
Old 11-21-2012, 05:25 AM
ooooh and i for got to say it desils when i turn it off but not when it stalls
