help with a e-locker
i just got a 88 yota pickup an it had the e-locker in the rear but it wasn't hooked up. I'm wanting 2 just hook it up on a switch all i can find when i search is with a relay. so dose in any 1 no how 2 hook it up with just a switch or the easiest way.
thanks
thanks
Don't be afraid of relays. The locker motor needs to work to engage and disengage the locker, so the polarity must be reversed, you could do this with two push buttons, but with one? That's going to be tough without relays.
Here is the factory wiring.
Why are you not wanting relays?
this is the kit i got but it didn't come with instructions.
i can use relays i just thought it would be easy 2 do it with out the relays but idk 2 use them if i have 2 or if its easier
i forgot 2 give u the link here it is http://www.inchwormgear.com/store/pr...products_id=36
justdifferentials
Just Differentials
06-13-2022 07:40 PM
1uzRunner
63
11-10-2018 03:58 PM
zz_denis
09-06-2015 03:43 PM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 07:15 PM
