Help Diagnose This Noise (engine)
I think it may be the fan clutch, but Im not sure. This is the noisiest 22re I've owned. Any ideas?
http://s53.photobucket.com/albums/g7...t=P1000507.flv
Hard to tell what the sound is with my crap computer speakers.....
Have you inspected the idler pulley?
Also spin the fan blades to check for sound and wiggle the fan to see if there is play in the clutch hub.....
Then you can take the belts off and spin everything, to see if anything is making noise.
well I'm not running any power steering at the moment and so the belt is not on the tensioners/pulleys could it still be making noise?
I figured pulley/bearing noise as well, Is there something like belt grease you can spray on the pulleys to quiet them down, something like belt grease? Or do I need to replace the bearings themselves?
my power steering pulley is a little noisy, it's not really a problem till the bearing goes then you have to replace it obviously, you could try oiling it i guess
Oh, right I just re-read that he said he had no power steering. I asked that cuz mine was making noise on cold starts a few weeks back and I noticed the fluid was a little low, topped it off and it's quiet now
I may end up checking the water pump as well. Its something as the other 22re engines I have had sound kind of like diesels at idle, this one is just loud.
Poncho0206
07-10-2015 06:21 PM
