Help diagnose 22RE oil leak
Old 04-03-2008, 02:49 PM
Justinvd's Avatar
Today I was wheeling and ended up blowing a coolant line, i was underneath fixing it when i seen what looked like oil. Its coming out of of what lookes like a sensor just below the oil filter but above the oil pan?any ideas? ill post some pics when i get home but i just thought i would see if anyone knew?
Old 04-03-2008, 02:53 PM
norcalsvx's Avatar
oil pressure sender
Old 04-03-2008, 03:00 PM
Justinvd's Avatar
Where the arrows are pointing haha
Old 04-03-2008, 03:02 PM
Justinvd's Avatar
Originally Posted by norcalsvx
oil pressure sender
So if it is leaking what should i do about it? replace it or?
Old 04-03-2008, 03:08 PM
norcalsvx's Avatar
maybe it's not the oil pressure sender(not 100% on that) but there shoudl be a sender in there, what was there before?
Old 04-03-2008, 03:10 PM
notanymore's Avatar
make sure it isnt loose or anything like that first, if not then replace it.
Old 04-03-2008, 03:14 PM
Justinvd's Avatar
Ill take a proper picture of it tommorow morning so you can see and yeah ill check to see if its loose. That picture i posted is not of my engine its just a random one so you could get an idea of where im talking about
Old 04-03-2008, 04:59 PM
Justinvd's Avatar
So will i only be able to get this part from the a dealership or?ill prolly just pick it up cuz ive confirmed its leaking and its not loose
Old 04-03-2008, 05:03 PM
DCYota's Avatar
You don't HAVE to go to the dealership to get it. Any auto parts store should have it. I prefer to use Toyota parts when I can...but if you need it in a pinch and the dealership doesn't have it, then an autoparts store like Napa or Advance typically carries them in stock.
Old 04-03-2008, 08:08 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
That is the oil pressure sender. You don't need to replace it unless it's bad or the threads are stripped. Otherwise, use some plumber's pipe joint compound. Much cheaper than a new sender and will stop the leak. Just put a solid, light coat on the threads and tighten the bugger down with a 24mm deep well socket until it's good and snug.
Old 04-03-2008, 08:23 PM
Justinvd's Avatar
It looks like its leaking from higher up though but i guess it could just be running down the back?could it leak from anywhere else?
Old 04-03-2008, 08:36 PM
thook's Avatar
On that side of the motor.... particularly since it's "higher up", the only other place would be the oil filter since it's located right above the sender. If the gasket wasn't oiled before you installed it, the gasket could twist and dislodge from the seat...or even tear...and not make a good seal. And, maybe it just wasn't on tight enough.???
Old 04-03-2008, 08:57 PM
Justinvd's Avatar
Oil doesnt go into the sender right?the only place it could leak from the sender is the threads?
Old 04-03-2008, 09:00 PM
norcalsvx's Avatar
can you get a close up pic of your oil filter and sender
Old 04-04-2008, 12:05 AM
Justinvd's Avatar
Its not leaking out of the filter, im 100% sure of that, its definately leaking from somewhere on the sender. Ill get a pic in the morning though if that helps. The oil filter i have is a brand new filter and i put oil on the seal so its sitting perfect with no leakage.
Old 04-04-2008, 01:00 AM
CyMoN's Avatar
i just replaced mine with a mechanical gauge mine was in so tight it broke off in the block and I had to tap it out don't over tighten it or it may break off then you will have to tap it out and it is a tight fit getting a drill in there I had to take my shock off to get the drill in there.
the1998sr5
15
07-14-2020 08:35 PM
Eggslinger
06-08-2019 03:32 PM
jakebarrett
07-10-2015 07:15 PM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Help diagnose 22RE oil leak
