Help! changed cd player now my high beams dont work
So i changed the deck in my truck the other day. I know it worked because it was in my parts truck and i had it set up in my shed as well, i went to put it in my rig and now it doesnt work, my highbeams dont work and my interior lights dont work. WTF?!
in cab fuses look fine so do the ones in engine compartment. is there any other fuse blocks in cab otehr than the small one on the drivers kick panel?
Both systems highbeams and in cab are on two separate fuses as well. Radio/Dash and Dome I believe are on the same fuse, but not 100% on that without looking at a fuse box top. Yours is a different year as mine, so looking at mine isn't gonna help.
The headlights fuse should only be under the hood. Dash lights/radio etc are in the kick panel. I don't think the kick panel feeds the power to under the hood to trip the headlight relays. But there is that possibility. Without looking at the wiring diagram I can't say for sure.
Scotttekoch
23
11-01-2021 12:41 PM
LSUMatt1514
06-26-2002 05:03 AM
