Help:Breaking the drive shaft nut loose
I'm about to pull my engine out and I'm wondering if it would be easier to break the drive shaft nut loose before pulling it out, or wait until I pull out the engine.
I thought about using the starter method.
thanks
thanks
you mean the crankshaft? If it is a manual trans, you could put in high gear with parking brake on to break it loose.
Thank you Alex, yes I mean the crank shaft.
I'll try to do it the manual while in gear method. I'm nervous at using the starter method now I have the throttle body off and fuel lines open.
FYI All,
I ended up using the starter trick. Had to unfuse the EFI (for the gas pump), remove all cables to from the distrbuter and hook up the battery again. One click of the key, a loud crack of the breaker bar hitting the cross member and I have a free nut.
Thank you all for the help.
FYI All,
Iceman4193
07-15-2015 04:48 PM
